Welding axle tubes to diff housing on Dana 30 on a JK Jeep.
Posted: Sat Jan 30, 2016 6:29 am
Hi there
Im thinking of welding my axle tube to the diff housing on a Dana 30 from a JK Jeep Wrangler. Its where the axle tube meets the cast diff case. Ive attached a pic of a damaged D30 axle and i have highlighted where i want to weld. (not the axle I want to weld!)
Although there are rosette welds for some reason they are just simply not strong enough and the axle tube seems to have movement.
Can I use a mig welder using ER70S-6 wire with Speedshield 5/2 (argon 93%, Co2 5%, O2 2%) thats the gas i have. i only have a 150amp 240v mig. No name chinese welder.
Or should I just use 7018 stick.
preheating is not an option for me.
thanks.
thanks.
