J_68
    Sun Oct 10, 2010 6:28 pm
nomatter what i do i cant get the flow meter to go above about 22
iv never had a flow meter before only regulators.
i do hear a slight hissing/flow of air from the top of the flow meter any time the tank valve is open, is that normal
any help would be great, thanks
Rugar
    Thu Jun 17, 2010 11:40 pm
    SO Cal
No that is not normal. Sounds like the flowmeter is leaking causing you to loose pressure. Mixed up some soapy water in a spray bottle and spray around all the fittings and the relief hole with the tank valve open. If you have a leak it will blow bubbles.
Millermatic 251
Spectrum 300 Plasma
Everlast PowerTig 250EX
Everlast PowerCool W300
Harris/Victor OA
Craftsman 13 Speed Drill Press
ProTools Air/Hydraulic Bender
48" Brake
Compressor, Notchers, Grinders, etc.
J_68
there are no leaks anywhere other than from on top of the flow meter tube inside the black rubber thing where the brass pc and the screen is
Rugar
    SO Cal
Im not following you on where the leak is, but differant brands are all a little different from each other. If the flowmeter is leaking anywhere it has a problem.
Millermatic 251
Spectrum 300 Plasma
Harris/Victor OA
48" Brake
J_68
is a flowmeter any better than a regulator or vise versa
since i am looking to replace this one
thanks
will be for c25 or straight argon
Rugar
    SO Cal
They both do essentially the same thing. Get whichever, but always check for leaks.
Millermatic 251
Spectrum 300 Plasma
Harris/Victor OA
48" Brake
sschefer
    Wed Aug 18, 2010 7:44 pm
WIth a gauge you just need to remember to set it when the gas is flowing like during pre-flow. It'll read higher when the gas isn't flowing and that messes some people up.
