Tack weld
Posted: Sat Aug 15, 2015 2:15 pm
by yamahablue
When you are tacking pieces together to hold them prior to running a bead do you move the tip of the gun or just hold it for a certain count?
Re: Tack weld
Posted: Sat Aug 15, 2015 2:31 pm
yamahablue wrote:When you are tacking pieces together to hold them prior to running a bead do you move the tip of the gun or just hold it for a certain count?
That varies by circumstance. If the parts are welded "free", where they may move with the shrinkage of the weld, I prefer small stringers, say 1/2" to 1" alternating sides, depending on application. For parts welded in a fixture, or by design unlikely to move much, I'll just hold the trigger for a second and move on.
Both methods are common.
Re: Tack weld
Posted: Sat Aug 15, 2015 3:24 pm
by yamahablue
Thanks. So, 3 out of the 4 tacks I did the wire stuck to. I'm sure there's a trick to avoid that.
Re: Tack weld
Posted: Sat Aug 15, 2015 3:43 pm
yamahablue wrote:Thanks. So, 3 out of the 4 tacks I did the wire stuck to. I'm sure there's a trick to avoid that.
What machine are you using? There should be some built-in -or- adjustable "burn-back" This is the wire feeder stopping a brief period before the current stops, and literally burns the wire back toward the tip, to avoid the wire sticking to the puddle.
Alternately, you can sharply move the gun just as you release the trigger.
Re: Tack weld
Posted: Sat Aug 15, 2015 3:49 pm
by yamahablue
It's a miller 211, im not sure if it has the feature your talking about. I could also use some advice on doing the actual weld but maybe I need to start a new thread?
Re: Tack weld
Posted: Sat Aug 15, 2015 3:55 pm
Yeah, it might be time to start a thread in the MIG/GMAW section.
The "introductions" page can get a bit crowded when we start having discussions here beyond "hello". :lol:
Re: Tack weld
Posted: Sat Aug 15, 2015 4:15 pm
by yamahablue
Otto Nobedder wrote:Yeah, it might be time to start a thread in the MIG/GMAW section.
Huh? This is the mig/flux section.
Re: Tack weld
Posted: Sat Aug 15, 2015 4:17 pm
:lol: :lol: :lol:
Sorry.... I was reading so many posts in "introductions" that I forgot where I was while replying to yours.
Multitasking?
Not today....
Re: Tack weld
Posted: Sat Aug 15, 2015 4:49 pm
by yamahablue
Ha ha, you had me worried I was posting in the wrong section.
So here's what I'm working on, 3/8 plate used as a spacer on top of a leaf spring pad, 3/16 I think. A couple things, the spring pad is not flat anymore, it has a slight crown and also the ends are rounded over, both create a wierd fit up. I'm 100% new but was just going to set the machine to the door chart (1/4" maybe?) and go for it. I'm not sure if I should run a stringer bead first and then weave over that or just one bead. The instructions recommend just welding along the front and rear, the idea being the spacer can more easily be removed if need be.
Re: Tack weld
Posted: Sat Aug 15, 2015 5:13 pm
I'd follow the instructions, and run a single stringer each side.
This is loaded in compression, so your welds will see very little stress other than the friction of the spring as it compresses/relaxes and drags across this.
Don't over think it.
Re: Tack weld
Posted: Fri Aug 21, 2015 11:18 am
by Boomer63
Different tack sizes for different jobs. Depends on how much you need and want it to hold. Yours look fine!
