wire size
Posted: Thu May 14, 2015 10:49 pm
by yamahablue
I am completely new to all processes of welding but picked up a mig and I'm hoping to be able to tackle some projects. I will be using mostly 3/16" steel plate but up to 1/4" welding it to aprox.1/8" steel. It will be some lap joints and some filet (?).
My question is what wire size would be best for this and some theory behind why would be great. I should also add that on some of this project there will be gaps that I'm hoping to fill.
The unit is a miller 211 and it came with a small spool of hobart .030 solid wire, looks to be made in china.
Re: wire size
Posted: Thu May 14, 2015 10:57 pm
by AKweldshop
I'd go with .030.
This is great wire at a great price. http://www.ebay.com/itm/2-10-lb-Rolls-E ... 20fa425dfe
I've burned a lot of it.
~John
Re: wire size
Posted: Thu May 14, 2015 11:00 pm
Yamahablue,
.030 is fine for the thicknesses you list.
If your wire feeder has trouble pushing it, .035 is more commonly available and stiffer. It, too, works with the sizes you want to weld.
Check the availability of the sizes at your local supply. I would suggest .035, but that's a personal preference.
Re: wire size
Posted: Thu May 14, 2015 11:23 pm
by ldbtx
A lot of what we do is personal preference, as Steve said. I too, prefer 0.035" wire because of the increased metal deposition. It's only about 16% more metal, but if you're filling gaps you'll welcome the help.
LDB
Re: wire size
Posted: Fri May 15, 2015 7:13 am
by exnailpounder
You can pick up 10 lb rolls of solid at Horrible Freight on sale sometimes for 12 bucks. Its good enough for practice and non critical repairs but I use namebrand wire for the serious stuff. I use 030 for most thingsin my 252.
