pez
  • pez
  • New Member
    Sat May 09, 2015 3:31 am
Hi,
I have been reading for a while and now have a question. I'm looking to expand my fleet, and have been offered a Transmig 255 transformer GMAW (MIG) power source (victor technologies, sold as Cigweld in Australia). The old 195 I have is hammered and the cost of all the bits (that are still available) is high.
The 255 is designed to work with a remote feeder (nothing built in) however this unit has been stripped (just the source left). Are all wire feeders close enough to the same that I could make something work? Money is an issue so I'd be scrounging for a second hand unit so don't know what brands I could find (probably a different CIG, WIA or even ESAB).
Apparently it came with a '2R' wire feed unit that is no longer current, with a 24V control signal and 7 pin connection.
LWS just wants to sell me a whole new setup, no help.
Any advice would be appreciated!
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
OK, you have a MIG machine without an external wire feeder. I would have thought you might be able to adapt one without too much problem. After all, the wire feeder usually only starts / stops the feed-motor (with speed control) and gas supply. The switching of power to the torch comes from the machine itself (into the wire feeder)
What about spares from this unit?
pez
  • pez
  • New Member
Just spoke with cigweld, and apparently there are all sorts of issues with the feeder control on the 255's - need custom pcb's etc plus poor spares availability :( They apparently configured it different to all the rest.
Speaking with a couple of other repair shops it's going to be ~$1200 to get something to work.
Think I'll pass, possibly get a Chinese pulse mig or something to play with instead. It'd be cheaper, and probably have better spares availability :O
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Ring around welder repair shops. Macroweld in Shepparton Victoria sell lots of second hand machines. Also Angus welder repair in Bendigo.
