gases
Posted: Tue Nov 03, 2009 8:39 pm
i
The Forum
https://forum.weldingtipsandtricks.com/
https://forum.weldingtipsandtricks.com/viewtopic.php?f=6&t=72
you are going to have to change gas argon or argon mix for aluminum and 75/25 for mild steeljaviajero wrote:hello, I'm not a pro welder, but I like to learn to weld mild steel and aluminum because I'm restoring an old 1970 Land Rover, I have a Lincoln 175HD pro pak, either may I use 100% Ar to weld mild steel and Aluminum without change bottle gas or what is the better gas 75/25 for mild steel?
Thanks for your advice
