So I purchased a Millermatic 252 my first MIG machine
Please keep in mind I have experience with TIG and STICK but never MIG
I am in an industrial space and I use my Syncrowave 250 on 460v
Miller offers two options for the Millermatic 252 (200/230v) and (230/460/575)
I opted for the (230/460/575) so I can save money on my electric bill
I currently have the machine hooked up to 3 Phase WYE and the voltage reads 210v L1 + L2
Im running it this way because i dont have an extra 460 plug yet.
The machine turns on without error and seems to be fine, however I cant get the machine to weld, it just spatters and spits out wire, am I just not understanding how to MIG weld or could the 20 deprived volts be the issue?
I am welding 1/8 mild steel , 18v/ 250wire speed (16on the tank 25/75)
any help would be great thanks!
Bill Beauregard
- Bill Beauregard
I would expect reduced output, voltage is lower than minimum. Is gas flowing? Can you hear it? Might your polarity be reversed? What's your wire? I'd begin by changing voltage, but I doubt that's what's wrong. Make very sure your ground connections are very clean.
- Braehill
Scott,
I'm no Mig expert by any means, but a few things that I found that will give you fits are that the gun is not fully inserted into the machine and this limits the gas flow by having the gas ports half blocked and the polarity wrong for the wire type. Make sure that it's getting good gas flow, you can loosen the drive wheels and pull the trigger to check this without feeding out a bunch of wire. Your polarity you stated is right for bare wire and gas.
Use one hand on the gun, and one to dial the voltage up/down to find the sweet spot.ScottSans wrote:So I purchased a Millermatic 252 my first MIG machine
When you get down too low on voltage, you'll feel the wire stubbing into the metal.
When the volts get too high, the arc will spatter and be unstable.
Your goal is in the middle somewhere.
You may want more amps on 1/8" though, try 300-350 ipm (or more) and dial it in the same as above.
I run my shielding gas at 25cfh.
Bill Beauregard
- Bill Beauregard
I'll try to read up on the subject. I was of the belief the 252 was single phase. I have one, I love it! It is the nicest, most pleasant welder I have ever used. I can't imagine a nicer welder. Three phase, I don't know.
Quite right! I had a brain fart. Our 252 is single-phaseBill Beauregard wrote:I'll try to read up on the subject. I was of the belief the 252 was single phase. I have one, I love it! It is the nicest, most pleasant welder I have ever used. I can't imagine a nicer welder. Three phase, I don't know.
I need to delete and edit.
ScottSans,
Bill is right...
You are not on three-phase, but 210 split-phase, which is a single-phase arrangement. You should have 210-240 between L1 and L2, and 105-120 between both L1 and common/ground, and L2 and common/ground.
The difference between 210 and 240 should mean nothing to that machine's output. The only difference will be a slight one in power consumption/heat produced.
Bill is right...
bigworm40 wrote:
Thats your problem right there, you should be using 75/25.
He's using 75/25.....don't worry....
FYI.bigworm40 wrote:That's your problem right there, you should be using 75/25.ScottSans wrote:I am welding 1/8 mild steel , 18v/ 250wire speed (16on the tank 25/75)
- IMG_4221.JPG (50.37 KiB) Viewed 2476 times
Bill Beauregard
- Bill Beauregard
Jody did a video using CO2 I'd guess 25/75 is somewhat like that. What's the CO2 added to steel mix do? Is it just to reduce cost? Or does it serve a purpose. The so called expert at Airgas told me I could use 75/25 for back purge with stainless. He sold me an exotic mix of helium, CO2, and O2 for MIG stainless. It was less than a proud success.AKweldshop wrote:FYI.bigworm40 wrote:That's your problem right there, you should be using 75/25.ScottSans wrote:I am welding 1/8 mild steel , 18v/ 250wire speed (16on the tank 25/75)
Bill Beauregard wrote:Jody did a video using CO2 I'd guess 25/75 is somewhat like that. What's the CO2 added to steel mix do? Is it just to reduce cost? Or does it serve a purpose. The so called expert at Airgas told me I could use 75/25 for back purge with stainless. He sold me an exotic mix of helium, CO2, and O2 for MIG stainless. It was less than a proud success.AKweldshop wrote:
FYI.
Bill,
Your reading it wrong.
I don't believe anyone sells 25% ar/75% co2.
Look at my pic again.
Co2 is an active gas.
Bill Beauregard
- Bill Beauregard
I'm not very observant. So they do it backward in Alaska. Still I wonder why we use any level of CO2 in inert gas. Is it less pure? Cost less to manufacture?
John should be able to explain what CO2, or any active gas, does to your arc, bead profile and why we add it. Also why we use argon and what it actually does.Bill Beauregard wrote:I'm not very observant. So they do it backward in Alaska. Still I wonder why we use any level of CO2 in inert gas. Is it less pure? Cost less to manufacture?
Superiorwelding wrote:John should be able to explain what CO2, or any active gas, does to your arc, bead profile and why we add it. Also why we use argon and what it actually does.Bill Beauregard wrote:I'm not very observant. So they do it backward in Alaska. Still I wonder why we use any level of CO2 in inert gas. Is it less pure? Cost less to manufacture?
Here's some good info on the subject....
http://r.search.yahoo.com/_ylt=A0SO8xYQ ... r2oE9A0Wc-
Bill Beauregard
- Bill Beauregard
This a tough crowd.. It was a joke.
Not a tough crowd. Just serious about the subject, so we don't always recognize a joke in the middle of a discussion.
I've had it happen to me, and these guys all know I'm a joker.
- ldbtx
That happened to one of my student workers when we got a 252 for our shop in the science building at the university I work at. He put the rig together and didn't get the gun in all the way, Drove us nuts until the Airgas rep we'd bought it from asked if the gun was fully inserted. We looked, it wasn't, we felt like idiots and fixed it. Welds great now. Just one of those live and learn things that bites us all in the butt from time to time.Braehill wrote:Scott,
ldb
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
Ok.....How do you know that little mistake???Braehill wrote:Idb,
Ask me how I knew that little mistake.
- Braehill
I actually did it twice and I seldom Mig weld. The first one was the first time in my life I ever mig welded and when I bought the Lincoln 180 I have now. I had it on the wrong polarity and the torch wasn't seated. Those welds were anything but nice.
I always check all torch connections, cables, switches before calling in our sparkies. I learned the hard way, when they flick a switch or tighten a cable. Embarrassing.
