Problem with penetration
Posted: Tue Feb 17, 2015 4:35 pm
by Jay1947
Hello, I am just starting here. Just second post after my intro.
First off the machine. A cheapie Northern flux core 125 with voltage set to high and wire speed at 2. Wire is US Forge heat WO15022 ,Alloy E71T-GS .030
Welding 1/8 steel into a T shape. Did a little destructive testing. When I ripped the 2 pieces apart the middle was
black and "cooked" looking. Any help will be appreciated. Thanks Jay
Re: Problem with penetration
Posted: Tue Feb 17, 2015 4:55 pm
by Wes917
Did you grind the millscale off both pieces?
Posted: Tue Feb 17, 2015 5:10 pm
by Jay1947
Yes, both pieces ground to shiny steel
Posted: Tue Feb 17, 2015 6:50 pm
by Artie F. Emm
Welcome, Jay1947! If it's helpful I found the manual for your machine, here:
http://www.northerntool.com/images/down ... 628575.pdf
I was hoping to find a chart or something to indicate what settings should be for 1/8" steel T joint, but no luck. You shouldn't be able to "rip the two pieces apart"! Can you post a photo?
Posted: Tue Feb 17, 2015 8:30 pm
by Jay1947
Will try photo tomorrow if my garage gets a little warmer. Never got to 32 today, in North Carolina..........J
Posted: Tue Feb 17, 2015 8:49 pm
by Braehill
That's 37* warmer than my garage was yesterday and 20* warmer than it was today, yikes it's cold.
Posted: Tue Feb 17, 2015 8:54 pm
by danielbuck
Did you have a whole lot of spatter next to the weld?
I hesitate to suggest this, since it's a flux-core only machine, but maybe the polarity is reversed? I don't know if you even have the ability to get the polarity incorrect on a flux-core only machine, but it's worth looking at, maybe they are connected up wrong.
It should still weld with the electrode positive, but you'll get a bunch of spatter and I imagine the penetration won't be as good? Maybe that's the problem here? Electrode Negative will have much less spatter.
Posted: Tue Feb 17, 2015 11:35 pm
by Jay1947
Braehil, lived in Westmoreland County for 36 years before I came south. Know what you mean...
daniel, good thought, plenty of spatter, will check tomorrow....J
Posted: Wed Feb 18, 2015 8:42 am
by jwright650
125 amp machine "should" handle the .030 wire OK, it's marginal, but it "should" weld. I have a Hobart Handler 135 and it likes the .030 wire a lot better than the .035. You should be getting a nice quiet hissing sound as you weld, if you're getting a lot of spatter and crackling like bacon frying then something isn't quite right. I agree with your voltage setting, and the WFS is something that you will have to adjust as you see how the puddle is doing....keep your stickout fairly short for that machine. Proabably around 1/2" to no more than 5/8". Stick out is measured from the tip to the work...the nozzle if equipped, has no relation, so ignore that when figuring your stick out. Check the polarity as suggested...that's about all I can think of, that machine "should" do the job for you.
Let us know how it goes
Posted: Wed Feb 18, 2015 9:48 am
by Braehill
Jay,
I live in Lower Burrell (Yes there's an Upper Burrell) Westmorland Co. and think about heading south every damn day. :)
Posted: Wed Feb 18, 2015 9:34 pm
Braehill wrote:Jay,
Don't you keep getting offers from the NOLA East facility?
Posted: Wed Feb 18, 2015 9:45 pm
by Braehill
Steve,
If they made an offer today after plowing snow for over half my shift, I probably would accept. F$&cking snow.
Posted: Wed Feb 18, 2015 10:06 pm
No snow here.
S'posed to get down to 27* tonight. Local plumbing crisis. :lol:
Posted: Wed Feb 18, 2015 10:41 pm
by Coldman
We have a cyclone bearing down on us right now :cry:
Hopefully only a category 1 or 2, but no snow.
http://www.bom.gov.au/products/national ... loop.shtml
Posted: Thu Feb 19, 2015 5:56 am
by Wes917
Just checked the temp -15f right now. Our high is said to be -13f low -23f. I ask my wife everyday why we still live here.
Posted: Thu Feb 19, 2015 7:49 am
by Braehill
And we call the guy living under a bridge in Miami crazy, hmmm.
Posted: Thu Feb 19, 2015 8:16 am
by jwright650
Braehill wrote:And we call the guy living under a bridge in Miami crazy, hmmm.
LOL.... :D
Posted: Sat Mar 07, 2015 5:16 pm
by Jay1947
Sorry it's been so long since I posted. A little sickness, drain problems and since I am retired she talked me into a vacation.
Can you take a vacation if you don't work ?? Anyway, haven't figured out how to post a picture. But today I managed to lay down a somewhat decent bead on a piece of flat steel. I thing my main problem is not seeing the weld. Played with the helmet settings and it got better. Cataract eye doctor didn't do a great job. Any way the welds I ripped apart had 1 decent looking side and the other was just like charcoal. Don't think was getting the weld into the right spot. Thanks for the help. I will keep "teaching" myself..............J
