    Sat Jan 31, 2015 4:58 pm
I just bought the Eastwood 175 MIG welder and I set it up and plugged it in to feed the wire through the gun and I noticed when I pull the trigger the wire starts where it should on a particular setting then slows down. It does this on all settings and barely moves at all when set at 1. Please help!!
Jon
Never mind I figured it out. I still had the line wrapped up on the cart. Works great now
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Good stuff.
jwright650
    Wed Dec 03, 2014 3:27 pm
You can adjust the tension on the Wire Feed drive rollers...don't tighten it where it crushes the wire, but it shouldn't slip too much either....sounds like it may be set a touch loose and the wire is slipping...also make sure that the drive rollers have a groove on them for the size wire that you are using.
John Wright
