Material temperature
Posted: Wed Jan 28, 2015 10:04 am
When welding something that requires multiple passes what should you let the original pass naturally cool to before running the next pass?
The Forum
https://forum.weldingtipsandtricks.com/
https://forum.weldingtipsandtricks.com/viewtopic.php?f=6&t=6842
bigworm40 wrote:When welding something that requires multiple passes what should you let the original pass naturally cool to before running the next pass?
It's called the interpass temperature and it changes for different metal types and different thicknesses.bigworm40 wrote:Is the're different temps for different processes? Guess I should have stated I'm using fcaw-g.
bigworm40 wrote:So I've been researching this a little and found a few posts that claim they have seen up to 150 degree f inconsistentakes When using an infrared gun. Has any one else seen this and what's is the preferred method for checking temps?
That's how I read itbigworm40 wrote:Im not following any code and have not been given any weld specs by the engineer, there for no preheat. What should it have been?
If i'm reading AWS D1.1 correctly with the type of steel i'm using the minimum preheat for anything .750 to 1.50 only requires a 50 degree preheat.
Dave,MinnesotaDave wrote:I found one of the references that would seem appropriate.
Are you referring to two different pre-heats for the same material?bigworm40 wrote:Dave,MinnesotaDave wrote:I found one of the references that would seem appropriate.
can you link where you found this please, looks like there's conflicting info.
A blanket rule of 350 deg is not accurate nor recommended. There are so many variables to consider, material type and types welded together, filler material used and process, material size, ambiant temperature, etc. If one were to follow this rule it could lead to problems if used for materials where this interpass temp would either be to low or high. Also, keep in mind that if you use a 350 deg interpass temp and I use a 200 degree interpass temp, your material will see more heat input than mine which could lead to all sorts of problems, again depending on variables.AKweldshop wrote:bigworm40 wrote:Is the're different temps for different processes? Guess I should have stated I'm using fcaw-g.
Keep it under 350 deg, between passes, and your good.
Superiorwelding wrote:A blanket rule of 350 deg is not accurate nor recommended. There are so many variables to consider, material type and types welded together, filler material used and process, material size, ambient temperature, etc. If one were to follow this rule it could lead to problems if used for materials where this interpass temp would either be to low or high. Also, keep in mind that if you use a 350 deg interpass temp and I use a 200 degree interpass temp, your material will see more heat input than mine which could lead to all sorts of problems, again depending on variables.AKweldshop wrote:bigworm40 wrote:Is the're different temps for different processes? Guess I should have stated I'm using fcaw-g.
I was talking to a good friend the other day about his welding and he was sharing with me how their WPS' call out specific interpass temps that are supposed to be followed. He follows them but others around him do not and always have problems with warpage and some of the material they weld cannot be fixed after welding. Interpass temp is very important.
Sorry for the "blanket" statement.Superiorwelding wrote:A blanket rule of 350 deg is not accurate nor recommended. There are so many variables to consider, material type and types welded together, filler material used and process, material size, ambiant temperature, etc. If one were to follow this rule it could lead to problems if used for materials where this interpass temp would either be to low or high. Also, keep in mind that if you use a 350 deg interpass temp and I use a 200 degree interpass temp, your material will see more heat input than mine which could lead to all sorts of problems, again depending on variables.AKweldshop wrote:bigworm40 wrote:Is the're different temps for different processes? Guess I should have stated I'm using fcaw-g.
^this, there are simply too many variables to make a blanket statement. I work with/write wps's and if interpass temps are violated, parts are scrapped, there's no reworking.Superiorwelding wrote:A blanket rule of 350 deg is not accurate nor recommended. There are so many variables to consider, material type and types welded together, filler material used and process, material size, ambiant temperature, etc. If one were to follow this rule it could lead to problems if used for materials where this interpass temp would either be to low or high. Also, keep in mind that if you use a 350 deg interpass temp and I use a 200 degree interpass temp, your material will see more heat input than mine which could lead to all sorts of problems, again depending on variables.AKweldshop wrote:bigworm40 wrote:Is the're different temps for different processes? Guess I should have stated I'm using fcaw-g.
