Spray tranfer on a transformer machine
Posted: Thu Nov 06, 2014 5:10 pm
by sunppeli
I have an old ESAB LAG315 MIG/MAG welder from the 80's. I was wondering if it is possible to use spray transfer on it. I'm using 1,0mm wire (~0,04") and argon with 18% co2. What kind of setting should I use?
Also I've been wondering about the relationship between voltage and current. Why do some newer machines adjust current and older machines adjust ampreage? On my machine, I guess, the voltage will increase when I turn up the current?
Thanks!!
Re: Spray tranfer on a transformer machine
Posted: Thu Nov 06, 2014 6:21 pm
by Shield Arc
Can your machine get into the high twenties for volts? I've read where guys say you can get into spray faster with 98% argon, and 2% oxygen.
This is .035” Lincoln's L-56 wire with C-10 gas.
Posted: Fri Nov 07, 2014 12:27 pm
by sunppeli
There is no way to tell how many volts it's putting out! It only has current switches on the front panel and a separate wire feeder unit. No digital meters on my welder
. If it's necessary to know the voltage, maybe I could measure it on a separate device between + and -? That way I could learn how to adjust the voltage?
That's a beautiful bead!!
Posted: Fri Nov 07, 2014 2:59 pm
by MinnesotaDave
sunppeli wrote:There is no way to tell how many volts it's putting out! It only has current switches on the front panel and a separate wire feeder unit. No digital meters on my welder
That works, just have someone read the meter while you are welding so you can keep a consistent bead and reduce the minor fluctuations that show on the meter.
Or just video the meter and play it back when finished.
Posted: Fri Nov 07, 2014 4:49 pm
Crank it up into the higher settings and then adjust the wire feed to suit, until you get a sound like cloth tearing.
