aluminum troubleshooting
Posted: Fri Apr 18, 2014 7:12 am
posted this over at hobart forum but thought ppl might have some view here. have a new 190 with spoolrunner 100 gun. put it together with 100% argon tank and 4043 .030" wire. trying to dial in the settings on some practice pieces of 1/8" 6063 (pretty sure as it is square tubing and corners are sharp not rounded) i'm having trouble and hoping someone can help.
started at the recommended 5/80 but it was burning through and welds were really flat. also had a lot of soot. played around and this is the trouble i'm having and questions:
1) power setting: seems like power at 4 gives a better weld (not too flat and not too high), temperature makes a huge difference as the start of the weld doesn't penetrate well and after about an inch it is better and at 3 inches or so it is way better. what is the best way to preheat? using map gas torch takes forever.
2) wire speed: this is my big challenge. i'm following the advice of longer stickout (3/4" or so). if i lower the speed down to get the nice hissing sound rather than the frying bacon sound i start burning up tips like crazy. if i watch the tip during the weld i see the wire pulsing shorter and longer rather than a constant length. i looked at the aluminum mig videos on wtt and it looks like the wire stays a constant length which may be why i keep burning tips?
3) soot: no matter how much or how little argon i use the weld is still full of soot. i was thinking i'm holding the tip too far but if i get too closer again i burn tips like crazy.
i assumed it would take a while to get it dialed in but the rate i'm going through tips can't be right.
any help is much appreciated
