jwmacawful
    Fri Aug 13, 2010 1:23 pm
    the city that never sleeps
i had to install those handcuff rings i fab'ed the other day but didn't want to push the ancient idealarc for a 1/4 mile so i took the 110. it did ok till the last piece when the breaker blew. instead of grinding the paint off all the spots i had to weld i should have ground one and welded and then while the breaker was cooling off ground the next.
That's wonderful!
You welded those cuff rings using a 115V portable?
Thats Irony! Handcuff rings done with a portable welder!
jwmacawful
Otto Nobedder wrote:That's wonderful!
with both mig and 110 stick. not at the same time though.
