How much heat/volts?
Posted: Wed May 29, 2013 11:59 pm
Hey,
So I've got a mig and tig at work, however, have never used a mig before and using the TIG is painfully slow for alot of the work that's been given to me lately, so would like to become proficient at using the mig. Have read most of the mig books and seen the DVDs but one thing seems to confuse me a bit.
How much heat do you set? I can tune the wirefeed to the voltage just fine, but when do you know you've got too little or too much voltage/heat? Assuming to little results in cold lap / overlap but it would also seem once you start to get good fusion/toe in, that you can just ramp the power up and travel faster through a pretty large range to get a similar weld.
So what is the go, Do you just set it such that you get good fusion and leave it, or ramp it up as fast as you can control the weld puddle?
Here's my first tries with MIG.
17v and 110amps (its a wierd machine that has amps not wirefeed but it does the same thing).
18.5v 135amps
Some critique would be appreciated too. I need to practice keeping my arc length steady i know that much but aside from that it seems the fusion is okay.
So yeah! What's the go with setting up volts?
Thank you muchly
Glen
18.5v 135amps
Thank you muchly
Glen
