Wire for 316 Stainless
Posted: Thu Apr 04, 2013 2:12 pm
by boyerd24
I would normally TIG anything stainless but I currently only have access to my Miller MIG machine. I need to do a small amount of welding on some thin 304 and 316 SS, and I am not sure what wire to go with. Does anybody have an suggestions for a wire that works well? I would also appreciate any tips or pointers anyone has.
Thank you for your help.
Re: Wire for 316 Stainless
Posted: Thu Apr 04, 2013 7:11 pm
308/308l/308lsi wires work fine for both 304 and 316.
Only if the 316 you're welding is in a highly corrosive environment would you need a 316/316l wire, which is available, but costlier.
Note that you should have the right gas for the job. 75/25 will give "fair" results, with much darkening of the weld. "Tri-mix" (90% helium, 7.5% argon, 2.5% CO2) is the preferred gas. If you can do it with 75/25, you'll require more heat than you'd use with the tri-mix.
Posted: Thu Apr 04, 2013 10:06 pm
by rake
A third option is Stain Mix 92% argon 2% CO2 A lot of shops have switched to this with the increase in Helium prices and lack of availability.
Posted: Wed Apr 10, 2013 8:02 pm
by williejack
Been my exp,rule of thumb no matter what welding process arc,mig,tig,as long as the rod, wire #is higher than the material your welding you will be fine.For example 304 stainless use 308,312,316 wire or rod,as far as gas selection tri -mix is the best ,but costly we always use 98/2.
Posted: Wed Apr 10, 2013 10:57 pm
by Alexa
