TechAero
    Sat Feb 16, 2013 4:12 am
    Sidney, B. C. Canada
Hi Guys. Dave Brown here from Sidney B. C. Canada. New to the forum today, but a big fan of Jody's Website and Videos. :) I run a small Machine and Fab Shop primarily catering to the Aircraft Industry in design and construction of Ground Support Equipment. I am an AME (Canadian Aircraft Maintenance Engineer) and have worked for over 35 years in Aircraft Maintenance annd overhaul of Lycoming Piston Engines and Garrett TPE331 Turboprop Engines.
In creating the types of ground support equipment that I do, quality of work and appearance is very important, as the engineers that use my products are very critical of "Fit, Form, and Function" and most seem to be "Welding Critics". Early on I bought a Millermatic 252 Mig Machine with the Spool Gun (love the machine) and fitted it with Stargold C-25 Shielding gas, which has worked very well to produce nearly spatter free, good looking, clean, sound, quality welds that need virtually no clean-up. The extra that I spend over CO2 is more than made up for in the lack of post weld clean-up, quality, and appearance.
A couple of weeks ago, when I needed a re-fill, I asked my gas supplier, PRAXAIR, if they has a gas that I could use with Stainless Steel and my MM Passport + for a portable SS job, as well as Mild Steel. They asked me to try STARGON VS as they were promoting it as a type of "Universal Gas". There is an article about it on the Praxair website by Larry Cherne of Praxair (larry_cherne@praxair.com) where he explains the mixture that was designed to "increase weld quality and speed". The gas is a mixture of 90% Argon, 8% Helium, and 2% CO2. The low CO2 content allows for welding of Stainless Wire with low Carbon to perserve the Stainless qualities, while the Helium content actually allows operation in the Spray Transfer range if your machine has enough power and duty cycle. Praxair has a pattent on this gas mixture.
Holy Cow! :P Fast and Clean is right. I have not used it too much yet and have not tried it on Stainless Steel, but on Mild Steel, it enters the Spray Transfer Range very easily (with higher voltage, 26.5 Volts and wire feed, about 350 IPM on 0.035 ER70S6 Wire for 1/2" MS in one pass) and does GREAT on heavier sections of Steel. Even at lower settings on smaller cross sections, it sprays easily at slightly higer than normal settings. (The file size of the picture that I had is too large to upload. I will have to reduce it's file size.)
Has anyone else used it? I would love to see Jody do a video on Shielding Gas Comparisons for MIG between CO2, C-25, Stargon VS, and get his opinion.
Dave Brown
MM 252
MM Passport +
Lincoln V205-T
Crafter Series WC Tig Torch
Miller Digital Elite with Cool Band. (Allows you to breathe without foging up so you can actually see what you are doing.) :shock:
Dave Brown
TechAero & Industrial Inc.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hey,
Welcome to the forum. Glad to have you. I think jody has a video on gas comparison, I think Tri- mix vs co2 check the search engine on the main WT&T page. Although it would be good to do a comparison of the Specialist gasses you speak of.
Welcome!
I believe I've used that mix, under a U.S. trademark. "Sunarc gold" or something like that, right when helium prices began to spike and Tri-mix became impractical for many smaller operations.
As I recall, it performed better than C25 for carbon, but not as well as tri-mix for stainless. (Bear in mind, this was short-circuit transfer, though. The mix sounds appropriate for spray-arc.)
I hope you get that pic resized (JPEG, <256K) and posted.
TechAero
Hey guys;
Figured it out, I think. Here are the two files. Notice the smoothness of the weld bead with no tendancy to undercut. Penetration is fantastic and I was able to shoot the wire down into the slot at the end of the plate and fill the slot in the bar stock from the root to the top in one operation. (Rosette Weld on the end of the plate.) Also note the discolouration of the heat affected zone. Very fast and clean as can be seen by these as welded pictures. Spray transfer works great, but just lower the settings to normal and it short circuits well too. They say that the cost is comparable to C-25, but I am not sure yet, however, given the ability to weld stainless and enter spray transfer by cranking things up a little is very interesting.
Close-up view of 1/2&quot; MS plate in a 1/2&quot; slot in a 1.5&quot; X 1.5&quot; solid steel bar stock.
Close-up view of 1/2" MS plate in a 1/2" slot in a 1.5" X 1.5" solid steel bar stock.
Normal View of a Pintle Ring for a DHC6 Twin Otter Tow Bar on Whipline Amphib Floats.
Testing and evaluation, as with all things, is a continual learning curve. I was impressed, and thought that I would pass it on. "Nothing ventured, nothing gained!"
Dave Brown.
TechAero and Industrial Inc.
Sidney B.C. Canada.
Dave Brown
Pics came through great!
Seems like a great gas for spray-arc. It's hard to argue with results!
