Hi there,
We made our own. A sleave of copper silver soldered onto the outside of a normal shroud/ nozzle. The end of the shroud sits square on the job, this sets the height and holds the gun square. With a little notch on each side to let the smoke and stuff escape. May need to do a couple of tests to get the height right. Remove the chrome plating (if any) on the nozzle. Not sure if it will solder well.
donaldsanchez
- donaldsanchez
If you want to buy a good quality welding nozzle then can buy it with the help of our company which is one of the best in making welding equipment. Te quality of our products re very good and can easily afforded from anywhere.
_____________________
Spot welding tips
Spot welding tips
