Weld distortion plate to box
Posted: Sun Mar 08, 2020 4:33 pm
Hello
I am new to MIG welding and have been making my own gym equipment using mild steel box section tubing.
Most of the connections for this equipment comprise of 10mm plate welded to 3mm thick box section ends to allow for bolt/nut securement.
After welding up I find that i can not keep the plate from curving inward and therefore the plate no longer sits flat against the face of the connecting piece of box section tubing. I find i have to cut and weld triangle shaped metal pieces to fit into the right angle between plate and box and this works great but there are times when i just want plate welded to box ends for simplicity and aesthetics.
I thought about tacking up then bending the plate in the opposite direction slightly prior to welding but will this method just snap the tacks off?
