    Fri Jan 04, 2019 12:25 pm
    Belgium
Hello,
Contact tip and stick out seem very important.
However, using my ESAB C200i, I cannot adjust the contact tip. It's recessed like 2,8mm.
The scope of use would be sheet metal welding (0,6 / 0,8 mm)
I know I could saw a bit of the nozzle...
But other than that, M6 threaded contact tips seem not to exist in different lengths.
Well, actually, they do, but they are a bit larger, as you can see in the attachment.
I have the first three, M6 25mm. The 3 in the middle are also M6 28mm, but larger.
How does that impact the flow of the gas?
Or does it impact something else?
Thanks again
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Try trimming the shroud back flush. Shrouds are a consumable item so you can afford to muck around with it. Also the specific brand of tip doesn't necessarily matter, as long as the thread is the same.
CWD and stick out beyond the nozzle matter more that the distance of the tip to the nozzle in my opinion. You might be attempting to arrange atoms in the middle of a hail storm with too much theory interfering with your practical execution of technique.
I do appreciate that you are attempting to learn how to do things properly and configure your equipment for the best results, but I dare say people have been welding for nearly 100 years with primitive equipment and producing perfectly strong, appealing welds without so much concern to some of the factors we focus on today. The best equipment won’t make a good welder, but a good welder can make better welds with good equipment (if you know what I mean). And some welders don’t care in the least about their equipment; they still produce perfect work.
    Belgium
Thank you for the trimming tip!
And yes, I know, I’m just like that. I like to ‘know’ things or at least investigate. Maybe because I have a scientific background :D
But, yes, as soon as my electrical ground is up to date, I’ll start welding miles and miles 8-). Nothing beats practice, you’re right.
homeboy
    Mon Dec 19, 2016 11:52 pm
    Southern Ontario Canada
I just ground mine back to slightly past the tip and give it a quick shot of anti-spatter spray every little bit. Any spatter just pops off.
    Wed Jan 22, 2014 12:00 am
    Connecticut
On some guns, like my Bernard Q gun, the nozzle is what changes in length to adjust the amount of contact tip recess or stick out.
Multimatic 255
