Criticize my welds please
Posted: Fri Jun 01, 2018 1:06 am
by Junior Welder
Hello all,
I have been mig welding approximately once a week/once in two weeks for almost a year now.
I have been welding almost each day for a week or two. Tonight I welded this scrap metal tee joint.
Can you give me some advice on what I could do better? Does correct machine adjustment make for les spatter?
Here are some pictures:
Re: Criticize my welds please
Posted: Fri Jun 01, 2018 1:08 am
by Junior Welder
More pictures
by Junior Welder
More pictures
Posted: Fri Jun 01, 2018 1:09 am
by Junior Welder
More pictures
Posted: Fri Jun 01, 2018 6:00 am
by tungstendipper
Are you using Flux-core wire?
Posted: Fri Jun 01, 2018 6:47 am
tungstendipper wrote:Are you using Flux-core wire?
If he is, he needs to reverse the cables and run DCEN to help eliminate the spatter.
Beads look good, travel speed is good, consistent tie-ins, heat looks right. Spatter is killing you.
Posted: Fri Jun 01, 2018 9:36 am
by theaceofgates
try adjusting wire speed just a bit. It might help.
Posted: Fri Jun 01, 2018 11:53 am
by Junior Welder
No.
I’m running 0.035 ER70S-6 solid wire with c25 gas
Posted: Fri Jun 01, 2018 11:54 am
by Junior Welder
theaceofgates wrote:try adjusting wire speed just a bit. It might help.
Up or down?
Posted: Fri Jun 01, 2018 1:20 pm
Up or down?
Yes.
And make certain your CWD is tight enough. Spatter can be symptomatic if long arcing it.
Posted: Fri Jun 01, 2018 11:47 pm
by Junior Welder
What do you mean by CWD?
Posted: Sat Jun 02, 2018 5:47 am
Junior Welder wrote:What do you mean by CWD?
Contact to Work Distance, HERE is a short write by Lincoln Electric
Posted: Sun Jun 03, 2018 12:57 pm
by Warrenh
Are you pushing or pulling and what settings are you using. Also, what gas? I am going to guess pulling from the look of the weld.
Posted: Sun Jun 03, 2018 2:21 pm
by Junior Welder
Ok thanks. As far as I know, I can’t adjust the contact tip recess on my gun. But I do try to hold a tight arc
Posted: Sun Jun 03, 2018 2:23 pm
by Junior Welder
Warrenh wrote:Are you pushing or pulling and what settings are you using. Also, what gas? I am going to guess pulling from the look of the weld.
I pushed this one. The Migmaster 250 doesn’t have any digital displays which tell the volts or ipm but I can tell you what I used If that helps. C25 gas
Posted: Sun Jun 03, 2018 5:33 pm
Sometimes you can tap the internal threads on the cup in or out. I’ve also ground down the copper tip to make the adjustment.
