One gas to rule them all..
Posted: Tue Apr 24, 2018 9:22 am
by Homemade
Is there a gas that will work with short circuit, and spray on carbon steel, and short or spray on stainless. And then throw hardsurfacing alloys. The place I work at, has a MM 252 running C25 and does all previously mentioned, minus the spray. Is there a gas that will cover all processes? I’m thinking 98%Ar 2%Ox will work ok for stainless and spray carbon but I don’t know about hardsurfacing or short circuit.
Re: One gas to rule them all..
Posted: Tue Apr 24, 2018 9:45 pm
by Franz©
That would be called stick welding in open air.
Might I suggest you become conversant with the work of Ed Craig. His site is called Weld Reality.
Posted: Sat May 12, 2018 5:12 pm
by ryanjames170
Ive been thinking on rolling over to Praxair's Stargon 90% argon, 8% C02, 2% O2 over C25 so i can do spray when i need to.
it dose good for spray and also dose good for short arc, I think it gose into spray at a lower amperage then C10 but im not 100%..
Posted: Sat May 12, 2018 8:46 pm
I think 95 / 5 will do it too.
