O.K. I know this should never be done, but I was in a bind. I mig welded a 3/16 thick 4 inch round pipe to a 1/4 thick plate embedded into a concrete base for a friend's HD plate steel mailbox. He lives somewhat remote, and I knew I had a gas problem as soon as I started. He needed the work done, and I couldn't figure out the problem. I proceeded anyway and just welded the heck of the pipe full circle. Yes, it looked like hell but seemed darn strong. I told my friend the problem and suggested he add several coats of cold galv spray on the weld before covering it up with topsoil and grass. I eventually figured out my line set connection to the welder was not fully inserted which prevented the O ring gas seals from doing their job. Do you guys think the weld will hold or should go back out there, cut it loose, and start over?
- Farmwelding
I know here in Wisconsin, ,mailboxes get pounded during winter. I'm sure that in Texas there are other problems. If I had done that and here came a plow truck it would be gone or a solid wind storm. I would redo it. If you continue have gas problems, stick weld it.
That weld will be severely compromised and very brittle. If there is any chance kids, animals, or cars can be damaged by it then definitely cut it off and start over. If this is a federally served mailbox that is delivered to by a us mail carrier, who might inadvertently get hurt by or damage to the mail truck, then cut it off and start over.
