Lap joint opinions
Posted: Sat Jul 29, 2017 11:42 am
by Brettm357
What am i doing wrong if possible
https://imgur.com/gallery/tm2MD
Re: Lap joint opinions
Posted: Sat Jul 29, 2017 12:57 pm
The rough edge on the top piece is probably from a combination of moving too fast, running too hot, or lack of cleaning of the mill flake. Otherwise it looks pretty good. You could try slowing down or running several beads to get the desired look. If you want to weld it in one pass then you may need to change wire size, so you can add more filler faster. Gun angle can also come into play on a lap joint. You could also try favoring the top edge more than the center of the joint. How thick is that metal?
Posted: Sat Jul 29, 2017 1:50 pm
by Brettm357
1/4 inch using gasless flux core 0.045 (1.2mm) size powered by 205 amp machine with wire speed set at 170ipm
Posted: Sun Jul 30, 2017 12:31 am
by Brettm357
Slowed down a little made sure wire was on front edge changed gun angle
https://imgur.com/gallery/VpGd9
Posted: Sun Jul 30, 2017 8:38 am
That looks a lot better! Nice
Posted: Tue Aug 01, 2017 9:04 am
by Brettm357
On the weld i noticed little pits in the weld at first i thought i was causing it on previous welds when i was chipping the slag but this one i did not chip - is this a form of porosity or is it normal
Posted: Wed Aug 02, 2017 7:27 pm
Took a closer look and I see what you mean. Grind into the weld and see if there are more holes under the surface or if it's just the one. Is there any chance there was any oil residue on the metal?
