Miller 251 problem
Posted: Sat Feb 26, 2011 4:54 pm
by Joe
My trusty Miller 251 has developed a stutter. It worked fine 2 days ago, then yesterday it began cutting out. I start the arc fine and I'm pushing along and the arc just quits momentarily then restarts. I'm welding at 18 volts and wfs of 250 ips. I haven't changed any settings since 2 days ago. I suspect the wire feed somehow because the wire does not stub into the work. Also, the wire doesn't burn back to the tip either. If I am patient and stop my forward progress and keep the trigger pulled, so far the arc restarts and I can continue welding. Any ideas appreciated.
Joe
Re: Miller 251 problem
Posted: Mon Feb 28, 2011 8:09 pm
by sschefer
The liner is dirty. Probably just as cheap to replace it with a new one.
Posted: Wed Mar 02, 2011 8:45 pm
by Joe
Thanks for the idea about the liner. That might be part of the problem. I'll look into it. But I think I improved things a lot by methodically going through and cleaning the rollers. I found them to be a little dirty. After cleaning them most of the stuttering cleared up.
joe
Posted: Wed Mar 02, 2011 9:57 pm
by joseph.mowery
Try blowing some air under low pressure from the gun end to clean out your liner also.
Posted: Sun Mar 06, 2011 11:47 am
by anthonyfawley
could also check the spool and make sure the wire is not crossed up.
Re: Miller 251 problem, running again
Posted: Tue Mar 08, 2011 9:11 am
by Joe
Thanks everyone for the suggestions. I'm up and running again after cleaning the rollers and making sure the wire on the reel wasn't crossed up. It's just something I had never run into before. I'll know what to check next time.
Joe
