First welds - welding cart
Posted: Fri May 12, 2017 12:04 am
by WeldItUp
Re: First welds - welding cart
Posted: Fri May 12, 2017 7:06 am
I noticed what looks like pealing paint around some of the welds. That can be a contributing factor to some of the smoke and extra spatter.
Posted: Fri May 12, 2017 8:46 am
by WeldItUp
Poland308 wrote:I noticed what looks like pealing paint around some of the welds. That can be a contributing factor to some of the smoke and extra spatter.
Posted: Fri May 12, 2017 8:49 am
by WeldItUp
The steel I'm using for the lower frame was from a old piece of gym equipment that is painted. I realized after starting on the project that the area I had prepped for welding wasn't large enough to keep the heat from affecting it. That will change today. The remaining steel I have is new, cleaned with soap/water and acetone over the weld areas
Posted: Fri May 12, 2017 10:04 pm
by homeboy
I just found a 4 1/2 in rust and paint remover grinder disc ( Canadian Tire ) which cleans off mill scale,paint or rust in a jiffy. They look a bit like course cotton candy with embedded abrasives. Just cleaning the areas before assembly will help. The nice thing is they don't score the metal like a grind stone or flap disc if that matters.
Posted: Fri May 12, 2017 10:50 pm
by WeldItUp
homeboy wrote:I just found a 4 1/2 in rust and paint remover grinder disc ( Canadian Tire ) which cleans off mill scale,paint or rust in a jiffy. They look a bit like course cotton candy with embedded abrasives. Just cleaning the areas before assembly will help. The nice thing is they don't score the metal like a grind stone or flap disc if that matters.
Thanks for the recommendation! If you're able I would like to see a pic of the disc you're describing. I have had various success with cutting wheels (used to cope the frames - first time doing that), grinding discs and recently flap discs. It seems they don't last too long, and if the grit is too coarse they certainly will eat away some material
Posted: Sat May 13, 2017 9:54 pm
by homeboy
To see a picture go to Amazon.com -3m sandblaster 9681-4 1/2in course clean+strip disc. EBAY also has them with pictures. I have been using the drill style for a while and just happened on the grinder style recently. Harbour freight has one also but not a very good picture. They aren't cheap but do work well. Good luck.
Posted: Mon May 15, 2017 11:57 pm
by WeldItUp
After some love and much needed attention to detail, a little more refresher from Jody's videos, grinding and redo of some welds, leveling and polishing, my project is almost done!
Posted: Mon May 15, 2017 11:59 pm
by WeldItUp
Posted: Tue May 16, 2017 12:11 am
Very nice result!
I like the pneumatic tires, to roll over damn near anything in a typical shop floor (cords, air hoses, random dropped nuts and bolts, etc.)
Steve
Posted: Tue May 16, 2017 12:58 am
by WeldItUp
Otto Nobedder wrote:Very nice result!
Steve
Thanks Steve! I debated back and forth on pneumatic vs solid, but I can say they roll over bumps and cords like a dream so far. They are 10" tires, 4" casters up front
Posted: Tue May 16, 2017 1:04 am
by WeldItUp
This is a pic of my "workshop" away from home
