I have seen a couple threads where there is reference to running solid wire with 100% CO2. What are the pros and cons of this practice? Is there any special considerations for running straight CO2?
Thanks for the help
The biggest "pro" is cost. 100% CO2 is much less expensive than, say, 75/25 Ar/CO2.
The biggest "con" is increased weld spatter to clean. The initial appearance of the bead is less attractive, too, but a wire wheel fixes that right up.
It's been so long since I welded straight CO2 that I can't guide you on differences in settings, though I recall they weren't much different.
Steve
Steve
- Farmwelding
I've done some straight CO2 and it isn't a ton different. If you look at the Miller weld calculator, you have to increase your voltage some to get a similar weld profile/strength. For someone who is doing stuff in their garage, I honestly would reccomend it. As Steve said-cheaper, and you don't necessarily have to get bottles filled at a welders supply store. Have a store that sells and fills paintball gear you can go there.
Artie F. Emm
- Artie F. Emm
Another 'con' is co2 welds hotter than argon-co2, so it tends to melt through thinner materials such as auto body panels.
Dave
aka "RTFM"
aka "RTFM"
I use 100% co2 pretty often. Once dialed in it welds very well - set 1 to 2 more volts over argon/co2 mix.
Spatter accumulates in the nozzle, so nozzle dip and a little cleaning once and a while is the deal.
