Fluxcore Wire Feed Speed
Posted: Fri Dec 30, 2016 1:26 pm
by LGLDSR
Greetings,
With respect to wire feed speed, I had read (or misunderstood) that this should be adjusted first rather than power output. Unit is a Lincoln 125HD.
Many thanks and a safe and Happy New Year to everyone.
Best,
Lyman
Re: Fluxcore Wire Feed Speed
Posted: Sun Jan 01, 2017 4:31 pm
by MinnesotaDave
Wire feed speed is your welding amperage.
The voltage needs to be high enough to weld properly at the set wire feed speed.
Too low of voltage and bead is narrow and rope like. Increasing voltage widens the puddle and flattens it.
Too much voltage spatters a lot.
However, if I need the full output of a low power machine, I often put the volts at max and then dial up the WFS to match it until it welds correctly.
Posted: Mon Jan 02, 2017 5:22 pm
by LGLDSR
MinnesotaDave wrote:Wire feed speed is your welding amperage.
Thanks Dave.
"Wire feed speed is your welding amperage.". Can you elaborate a bit on that?
Thanks,
Lyman
Posted: Mon Jan 02, 2017 8:45 pm
by PeteM
Here is a good article on the subject of CC/CV power sources and their applications.
http://www.lincolnelectric.com/en-gb/su ... utput.aspx
Posted: Mon Jan 23, 2017 6:43 pm
by LGLDSR
Many thanks to all who responded and I apologize for the delay in replying!
Best,
Lyman
