Trying to find a spool gun
Posted: Sun Oct 23, 2016 12:05 am
by tberg
Hi everyone. I'm trying to find a spool gun for my esab multi master 260. I've searched on eBay and found that the St23a is very expensive. Was wondering if anyone has used a different gun on this machine and if so were do I find it. This is my first welder and I'm not exactly sure how to look this stuff up. Also would a shorter gun with a teflon sleeve and a set of aluminum drive rollers do the trick for now? Any input would be appreciated. :) Thanks Tom from toga ny.
Re: Trying to find a spool gun
Posted: Sun Oct 23, 2016 1:35 am
by tberg
Posted: Mon Oct 24, 2016 2:44 am
by tberg
So after more research my question has changed. Lol. Will any 8-pin amphenol spool gun work? Or even a 8-pin control adapter to change the pin connection?
Posted: Mon Oct 24, 2016 6:44 am
You have to find the 8 pin that is for your machine. Different brands sometimes use different 8 pin connectors. Even if they are the same size they may use a different pin configuration. Sometimes the manual will tell you what the pins are used for and then you can cross referance if there interchangeable.
Posted: Tue Oct 25, 2016 7:38 pm
by tberg
Thanks Josh. I may have found the one I need on eBay. Hopefully no one out bids me. Lol
