Miller 252 Issue
Posted: Sun Sep 25, 2016 3:28 pm
by Rick_H
Not sure what I have going on with the 252, I can weld about 4" or so and it repeatedly stops/cuts out. No fault code and another pull of the trigger and it resumes just fine. 19v 230 wire.
Any ideas, it repeatable can do it over and over...
Re: Miller 252 Issue
Posted: Sun Sep 25, 2016 4:23 pm
by Farmwelding
Check and see if "spot time" got turned on. Spot time will stop the arc after a certain time that you set and then pull be trigger again and it starts. Miller has a video on how to do it or it will be in your manual.
Posted: Sun Sep 25, 2016 5:58 pm
by Rick_H
Thank you very much, that was exactly what it was... I never even new that existed.
