Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Not sure what I have going on with the 252, I can weld about 4" or so and it repeatedly stops/cuts out. No fault code and another pull of the trigger and it resumes just fine. 19v 230 wire.
Any ideas, it repeatable can do it over and over...
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
Check and see if "spot time" got turned on. Spot time will stop the arc after a certain time that you set and then pull be trigger again and it starts. Miller has a video on how to do it or it will be in your manual.
Rick_H
    PA/MD
Thank you very much, that was exactly what it was... I never even new that existed.
