Sacman
    Thu Jan 05, 2017 9:05 pm
    East Meadow, New York
Here is my machine that I'm using. According the website they made several different models "weld pak 100" hd and plus. They all seem to be the same,just wondering is all. Thanks guys for all your useful help and knowledge it's appreciated. Image
cherwolf
    Thu Oct 30, 2014 11:13 am
    Latvia
sacman, set voltage to B. Then take a gun in one hand, another hand shall grab the wire speed control knob. Grab piece of scrap metal, thick one preferred. Begin to weld one handed and adjust your wire speed with another hand. If it is too slow you gonna see slow large droplets of metal falling, if too fast, your wire will stuck in the puddle and spark a lot as an arc can not melt it so fast. Find those two extreme points, too slow and too fast and turn your wire speed knob in the middle between those two - that`s your welding current. Nice buzzing low spatter euphoria. If you need more energy, move to C and repeat the story.
Ooops, flux core, but, should work. Just drag not pull your welds. And move your gun in C pattern.
Get a better helmet. I don't think you can see the puddle, or the "line" that you're supposed to be following from the weld joint.
Sacman
cherwolf wrote:sacman, set voltage to B. Then take a gun in one hand, another hand shall grab the wire speed control knob. Grab piece of scrap metal, thick one preferred. Begin to weld one handed and adjust your wire speed with another hand. If it is too slow you gonna see slow large droplets of metal falling, if too fast, your wire will stuck in the puddle and spark a lot as an arc can not melt it so fast. Find those two extreme points, too slow and too fast and turn your wire speed knob in the middle between those two - that`s your welding current. Nice buzzing low spatter euphoria. If you need more energy, move to C and repeat the story.
10-4 will do, thanks for the advice.
Sacman
Oscar wrote:Get a better helmet. I don't think you can see the puddle, or the "line" that you're supposed to be following from the weld joint.
yeah I brought a new auto dimming helmet and was messing settings in the beginning of the night those pics where taken. Thanks for the friendly advice.
I stand corrected. I pulled out the manual for the Millermatic 252 today, and looked at the volt/amp curves, and OCV does not match setpoint voltage below about 50A, or basically while not welding.
Our ancient Lincoln CV305 transformer machine does seem to match OCV to the setpoint whether it's loaded or not.
My bad...
Sacman
Otto Nobedder wrote:I stand corrected. I pulled out the manual for the Millermatic 252 today, and looked at the volt/amp curves, and OCV does not match setpoint voltage below about 50A, or basically while not welding.
My bad...
Ok so your saying my machine is a transformer machine? I haven't had a chance to use the volt meter while welding yet. Should I still? Sounds like I don't. lol I think. I read the manual I don't remember seeing anything specific like that in there. I have a lot to learn, thanks.
