Notapro
    Mon Nov 28, 2016 6:50 pm
    Central Wisconsin
I have a lincoln 100 weld pak that has been sitting in the corner since I purchased a 140 millermatic, I cleaned it up and thought to give it a last test run before putting it in the classifieds, I cranked the voltage to max and dialed in the wire speed and was amazed how that thing hung in there! Three consecutive passes. I vee it out and filled it up.
Notapro
    Central Wisconsin
    Thu Dec 25, 2014 9:25 am
    near Chicago
I sold mine and I regret it. Got the same welder given to me that still had the original spool in it. Don't even remember why I sold it but I know I have wished at least 10 times that I wish I still had it.
AKmud
    Fri Jan 25, 2013 1:47 am
    Wasilla, Alaska
That's what I started with 18 years ago. It's just too handy to get rid of.
Notapro
    Central Wisconsin
After using it I am thinking twice about selling it, no calls on it yet so I may keep it by default. Thanks guys.
Artie F. Emm
    Thu Jul 24, 2014 7:53 am
Did you break an axe head?! Or just practicing on it?
Dave
aka "RTFM"
Notapro
    Central Wisconsin
The ax head was broken, found it that way. It was separated thru to the handle hole. I should have taken a photo prior
We shouldn't underestimate the 120 volt machines. I have a Lincoln SP 135+ that I keep loaded for FCAW just for quick small repairs, outdoors jobs, and to loan to friends, etc. I used it to build a rack for my pickup, among other projects. Neat little machine.
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
ryanjames170
    Sun Sep 25, 2016 12:46 pm
    Wisconsin
ldbtx wrote:We shouldn't underestimate the 120 volt machines. I have a Lincoln SP 135+ that I keep loaded for FCAW just for quick small repairs, outdoors jobs, and to loan to friends, etc. I used it to build a rack for my pickup, among other projects. Neat little machine.
some of the newer 120V machines can really put out too.. especially the inverter based machines.. seems to me most people are still inthe thought process of that you cant get anything out of a machine unless its 220v due to just how inefficient the older transformer machines were. the power draw on my 160 amp DC stick machine is nearly half that of a transformer machine of 30 years ago.. witch alows it on evan 120V to put out good current something in the neighborhood of 90-120 amps depending on breaker size.
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
Klutch Plasma 275i Plasma Cutter
Hobard/Smith Oxy Torch using propane.
Notapro
    Central Wisconsin
I know our local welding shop has some of the newer miller dual voltage mig machines and they are very happy with them,
ryanjames170
    Wisconsin
Notapro wrote:I know our local welding shop has some of the newer miller dual voltage mig machines and they are very happy with them,
dual voltage is the way to go on any welder.. my stick welder is dual voltage, wish my Wire feed was.. it seems dual voltage machines give you the best versatility as i hate to say it unless you got a very scoocum welding gen set you cant always bank of having 220V at a job sight.. as most people dont have 220v at the house for more then the dryer, stove and central air. this is the predicament i am in right now i can only get 220V at from my gen set.. and that is limited at best..
Welder/Fitter
RM Fab & Products
    Thu Dec 26, 2013 12:41 am
    Laredo, Tx
I can get 240V anywhere. Portable genny with a 100-ft extension, with a 240V 6-50R and two 120V 15/20A outlets. That extension weighs at least 60lbs :)
Notapro
    Central Wisconsin
Oscars
How do you like the Eastwood plasma?
    Laredo, Tx
Notapro wrote:Oscars
Its fine for hobby level work. A couple quirks here and there but over all its a good hobbyist value. Will "cut" 1/2" if you really need it to.
Sacman
    Thu Jan 05, 2017 9:05 pm
    East Meadow, New York
Notapro wrote:
I was given this same machine, I wasn't sure if it was a good machine. I'm new to welding and learning with it. Hoping to get some pics up soon of my progress to get some opinions etc.. Did you only use flux core while using this machine? Have you ever use gas with regular wire in it? Thanks
ryanjames170
    Wisconsin
Sacman wrote:
i would think for your first welds before you get gas unless you have it already i would Run fluxcore threw it.. alot cheaper in the start, can see if the machine works good and what not.. as gas dose cost a bit to first get into.. where as fluxcore is maybe $20 for a spool of wire..
Welder/Fitter
RM Fab & Products
Sacman
ryanjames170 wrote:
Will do, thanks for the advice. The way it was giving it was given to me, it's set up with flux core already. It did come along with a bottle of argon/co2 bottle. I'm clueless to what it cost to fill or set up(Meaning flow rate etc). Out of curiosity would it be better to start with was using gas? I've used it a few times already. But I'm looking to put more time in with it and was wondering if there was a huge difference. I'm still in the middle of watching videoes of beginning of mig welding on here still. Lots of info, and didn't get that far. Lol hard to watch stuff when my children use the electronics all the time. Thanks
ODIS
  • ODIS
  • Active Member
    Mon Dec 12, 2016 9:36 pm
    Minnesota
The weld pac 100 is my first machine and I still have it. I recently bought a Hobart 210 MVP but I'm going to keep the little Lincoln and dedicate it to .023 wire and C25 for sheet metal and the Hobart will be dedicated to C02 and heavier wire. I bought the Lincoln in 98 and it has held up quite well.
ryanjames170
    Wisconsin
if you have the set up already and it has a good regulator.. i personly have gotten away with 10-12 CFH inside. as far as filling it up being as you have a bottle (provided they will fill it for you) u should be able to get prices from a local welding suppler.. keep in mind they may not refill the tank though so if you can take the tank with you to make sure they will..
but as for starting out i stand by flux core as you dont have to worry about the gas aspect of things. how ever if you got some gas and some wire i would run a few beads with it once u get a feel for the machine..
Welder/Fitter
RM Fab & Products
Sacman
ODIS wrote:The weld pac 100 is my first machine and I still have it. I recently bought a Hobart 210 MVP but I'm going to keep the little Lincoln and dedicate it to .023 wire and C25 for sheet metal and the Hobart will be dedicated to C02 and heavier wire. I bought the Lincoln in 98 and it has held up quite well.
Nice, its good to hear that the 100 is a good machine to begin with. I wasn't complaining, I was interested in welding and someone gave me a a welder. When I did general googling to find more information on the machine. I found alittle more negative then positive, until I came here and found out different. Thanks.
Sacman
ryanjames170 wrote:if you have the set up already and it has a good regulator.. i personly have gotten away with 10-12 CFH inside. as far as filling it up being as you have a bottle (provided they will fill it for you) u should be able to get prices from a local welding suppler.. keep in mind they may not refill the tank though so if you can take the tank with you to make sure they will..
Yup, not sure about the quality of the regulator. I'll snap a picture of it and post it. I going to start with the flux core, I dont have regular wire yet and just use what I have to practice. Out of curiosity is there a rule of thumb for setting gas flow? Also as for refilling the bottle. I didn't know the same bottle will be refilled, I assumed that it would be an exchange like propane. Thanks for the advice.
Sacman
Here is the regulator I have, It seems to look dated. What do you guys think? I'm not too sure,Thanks.
It is an older regulator. Think there may be an Allen screw in the middle of the back of the regulator for adjustment. If not then I would recommend a new one. After a while the springs can get weak inside or the diaphram may be getting brittle.it may even have cracks or holes. Either way that style doesn't appear from the picture to have a way for you to see the leaving pressure or more importantly the flow rate. Invest in a flow meter that goes over the end of your gun/ or torch otherwise adjustments are impossible or just wasteful.
Sacman
Poland308 wrote:It is an older regulator. Think there may be an Allen screw in the middle of the back of the regulator for adjustment. If not then I would recommend a new one. After a while the springs can get weak inside or the diaphram may be getting brittle.it may even have cracks or holes. Either way that style doesn't appear from the picture to have a way for you to see the leaving pressure or more importantly the flow rate. Invest in a flow meter that goes over the end of your gun/ or torch otherwise adjustments are impossible or just wasteful.
Agreed, I was looking closely at hose as well and it's cracked and dry. Im sure it was probably from just sitting in a corner and not being used before it was given to me. That being said I wouldn't be surprised if the regulator was the same. Thanks.
