- TRACKRANGER
Shannon
Pretty impressive items there.
Presumably you used a positioner rotator for the pipe work?
What is the actual diameter, and I wonder would you share your machine settings?
Trevor
Trevor
ImLow78
- ImLow78
Trevor, there was no positioner/rotator used on the pipe. The pipe IIRC was 6" or 8" dia with a wall thickness of 3/16" or 1/4". It's all done manually and welded with a millermatic 252. Wire .035, 19.9v, 310ipm wire speed and c25 gas.TRACKRANGER wrote:Shannon
Trevor
Here is some shots of my root and cover passes on 14' dia casing 3/4" wall welded with 212 innershield welded in 2g.
Root
Cover
Over view Photos of that job.
Shannon
ImLow78
- ImLow78
Trevor, here is a 120' string of cans (5 cans) 12' dia 1" wall that we welded in 5g on the ground and they used a 650 ton hydro and a 275 ton crawler to pick it off the ground and stand it vertical before putting it in the hole.
This job was welded with nr-233 wire.
Shannon
Shannon
Impressive work Shannon!!!
ImLow78
- ImLow78
Thank you. I'm no where I would like to be but for only three years in I'm happy. It's been hard work but it's paying off. I've got bunches of photos of projects I've done or helped with if you guys would like to see them. Everything from cars to industraial stuff.AKweldshop wrote:Impressive work Shannon!!!
I'm currently working on some super structure used for pump jacks. This next set we build (this week) I'll shoot some photos of my vertical up and Chinese vertical with .045" (and possibly 1/16") dual shield. I rock .045" but I'm still working on that 1/16".
Shannon (jack of all trades but master of none)
ImLow78 wrote:Thank you. I'm no where I would like to be but for only three years in I'm happy. It's been hard work but it's paying off. I've got bunches of photos of projects I've done or helped with if you guys would like to see them. Everything from cars to industraial stuff.AKweldshop wrote:Impressive work Shannon!!!
Please share some more pics of your work!!
I love looking at others work, I've shared pretty much all my work on these forums in the last year, and its lots of fun!!
ImLow78
- ImLow78
AKweldshop wrote:ImLow78 wrote:Thank you. I'm no where I would like to be but for only three years in I'm happy. It's been hard work but it's paying off. I've got bunches of photos of projects I've done or helped with if you guys would like to see them. Everything from cars to industraial stuff.AKweldshop wrote:Impressive work Shannon!!!
I just started a project thread. Here is the link guys. Keep watching it for I'll post what I can till my photobucket account runs out of bandwidth.
http://forum.weldingtipsandtricks.com/v ... f=9&t=5864
Shannon
forrestderp
- forrestderp
danielbuck
- danielbuck
Playing with my new machine!!
Haven't done much mig welding in about a year.
Warming up on some 3/8" by 2" flat bar.
Flat and vertical.
Flat and vertical.
- IMG_9877.JPG (54.72 KiB) Viewed 1527 times
- IMG_9875.JPG (54.3 KiB) Viewed 1527 times
- IMG_9912.JPG (47.83 KiB) Viewed 1527 times
- IMG_9913.JPG (56.54 KiB) Viewed 1527 times
- IMG_9915.JPG (51.15 KiB) Viewed 1527 times
- IMG_9920.JPG (43.16 KiB) Viewed 1527 times
Tad to much spatter, still haven't found the sweet spot.
- IMG_9921.JPG (45.49 KiB) Viewed 1527 times
- IMG_9928.JPG (52.91 KiB) Viewed 1527 times
- IMG_9930.JPG (41.46 KiB) Viewed 1527 times
Now some vertical.
19.5v, 230ipm...
19.5v, 230ipm...
- IMG_9933.JPG (70.74 KiB) Viewed 1622 times
- IMG_9934.JPG (68.24 KiB) Viewed 1622 times
- IMG_9935.JPG (67.67 KiB) Viewed 1622 times
- IMG_9937.JPG (76.71 KiB) Viewed 1622 times
- IMG_9939.JPG (82.56 KiB) Viewed 1622 times
- IMG_9959.JPG (79.33 KiB) Viewed 1622 times
Mig is so fun
- IMG_9960.JPG (66.73 KiB) Viewed 1622 times
- IMG_9961.JPG (64.77 KiB) Viewed 1622 times
Tried my hand at .045 duelshield...
3/8" to 1/2"....
3/8" to 1/2"....
- IMG_0046.JPG (77.12 KiB) Viewed 1607 times
- IMG_0053.JPG (84.96 KiB) Viewed 1607 times
- IMG_0052.JPG (57.96 KiB) Viewed 1607 times
Vertical up, not mine but one of my students, he is getting very close. This kid is steady as a rock. Not sure what his arc control/inductance was set at but a little more would have helped smooth it out a bit.
Lincoln Invertec V350
3/8" Mild Steel
0.035" L56
CO2
19 volts
John
3/8" Mild Steel
0.035" L56
CO2
19 volts
John
- image.jpg (58.02 KiB) Viewed 1498 times
- image.jpg (38.8 KiB) Viewed 1498 times
Nice dimes mate....
AK, does that new ESAB still have the buttery smooth arc that the old migmaster 250's had? Used to have an old Ltec 250. Arc was so soft I thought there was something wrong with the machine the first few times I used it. That was coming from a lincoln 175+
When good welds go bad. Very bad.
- IMG_20141025_115740.jpg (40.8 KiB) Viewed 1470 times
