hello I am buying a mig welder I was planning to use flux core wire with it but then I heard of co2 welding would this be a good idea for a beginner welder with some experience... this appeals to be because of the low cost and no slag would this be a good idea.,..
thanks
Artie F. Emm
- Artie F. Emm
I have only read about using co2 for shielding gas, but what I've read is that it can be used on thicker carbon steel. It provides good penetration but also a lot of heat. So you can use it, but probably not for auto body panels, for instance.
WT&T.com has some MIG with co2 videos:
http://www.weldingtipsandtricks.com/mig ... g-co2.html
http://welding-tv.com/2011/11/30/mig-we ... ing-gases/
Just a reminder- don't mean to sound preachy, sorry if you already know this- but flux core wire and solid wire use different polarities, so you'll need to set it accordingly.
Good luck with it!
Good luck with it!
Dave
aka "RTFM"
aka "RTFM"
For a beginning welder, either one will be fine. It will depend on what you are wanting to do. If your working outside most of the time, I would use self-shield flux core. The co2 is also a good choice as it I realitvely inexpensive to purchase. While it does promote good root penetration, it also has more spatter and slightly different settings. I would recommend learning both as you will have the need for them as you do more projects. If your budget allows it I would go for 75% argon/ 25% co2 mix as this produces great penetration, less spatter and your toes will wet out a little better.
Let us know which you go for.
