Threw this grill stand together with odd ball stuff laying around. Used my TA 181I to mig this together.
Hey,
Looks great, though Ill recommend a lip on the front and back of the table, to prevent the grill falling if it "creeps" duing multiple opens and closes.
I built a creeper for the long ecds that our shop builds. Its a track on hinges. There is a wheel on one side to make it easy to get threw the tube. We also built a bracket with v grove wheels to hold the creeper on the track. Right now I'm working on a guide for the tube.
Well ist not letting me add pictures ill have to add to photpbucket when I get off work
Moon,
Very nice! A few questions; what is ecds (didn't take the time to look it up) and what size and grade is that pipe?
Had a rush job today. Customer needed these DOM tubes welded for something used in the Frack industry. The only catch in these welds was I had to get the weld as close to the edge of the tube without to much of it off. Was a fun little job. I love using the rotisserie!
- orbital weld.JPG (110.98 KiB) Viewed 1804 times
I got all 12 of them done. Was a good easy job, wish more like this would show up! My wife was out there taking pictures of me and she did not believe me when I said I would post them here. Here is proof that I do get to weld once in a while.
Oh and a real weldor wears pokadot beanie.
- photoBEI8XHKU.JPG (119.95 KiB) Viewed 1777 times
- IMG_2058.JPG (122.74 KiB) Viewed 1777 times
- IMG_2055.JPG (107.63 KiB) Viewed 1777 times
For those who want to know what I do at my day job, here it is. Our patent was published a few months ago and we are realeasing these videos to the public so now I can share. This has been a 5 year project thus far and will have a couple more years until everything is completely done. The machine pictured is designed to be used in mainly tunneling applications but we will be also targeting open trench as well. We built everything on the machine from a pile of steel and had machining done elsewhere. In its current state it will push 30" 3/4" wall pipe for 5 miles up a 2* incline, generating 1.2 million pounds of max thrust. A complete stroke takes less than 3 minutes, so our hold up is the welding. The clamping system can be changed to accept 8" up to 42" pipe. The rollers I posted earlier in this thread can be seen in the first of the video. I am in the middle of designing a welding station to incorporate orbital welding to increase production and allow the machine to operate efficiently. Soon I will post actual pictures of the machine as it is a little different than the video. There are clamps at both ends in real life, not one. Anyway thought I would post this up.
http://www.youtube.com/watch?v=jEKh_FrPM7E
Last edited by Superiorwelding on Sun Jun 29, 2014 10:25 am, edited 1 time in total.
- Braehill
Jonathan,
That's pretty cool, I must say. The video must of taken quite a bit to produce just in itself. Cool stuff.
Kinda bored today so we started in on our 3G mig. Only picture I took but good reference anyway. This is the second pass. Specs; Pulse on 350MP .035 ER70S-6, 90/10 gas, 165 WFS, .96 trim. Runs like a champ.
- image.jpg (100.99 KiB) Viewed 1754 times
Might as well put this up too. Trying out my Cougar pistol gun and loving it! Here's the best I have do far. Won't bore on specs as there are to many for this. Feel free to advise how it can be better.
- image.jpg (106.35 KiB) Viewed 1753 times
Very nice drifta-x! What are your specs on that and did you whip those beads? Looks kinda line there is a weave pattern.
Thanks, I should have paid better attention to the 3F part and I would have not asked about the weave
Looking good, are you certifying now or just practicing?
Part of my weld to australian standards module for my cert 4
Was very pleased with it.
Shame iPhone4 takes average pix.
Messed around yesterday with some 7018.
Only really done arc to help other students once my module was done, so was time to Prac on 3/8 in 1g again with a 3/32 open gap and land.
Slowly getting better
- image.jpg (49.04 KiB) Viewed 1701 times
I have a soldering iron!
Impressive!Superiorwelding wrote:For those who want to know what I do at my day job, here it is. Our patent was published a few months ago and we are realeasing these videos to the public so now I can share. This has been a 5 year project thus far and will have a couple more years until everything is completely done. The machine pictured is designed to be used in mainly tunneling applications but we will be also targeting open trench as well. We built everything on the machine from a pile of steel and had machining done elsewhere. In its current state it will push 30" 3/4" wall pipe for 5 miles up a 2* incline, generating 1.2 million pounds of max thrust. A complete stroke takes less than 3 minutes, so our hold up is the welding. The clamping system can be changed to accept 8" up to 42" pipe. The rollers I posted earlier in this thread can be seen in the first of the video. I am in the middle of designing a welding station to incorporate orbital welding to increase production and allow the machine to operate efficiently. Soon I will post actual pictures of the machine as it is a little different than the video. There are clamps at both ends in real life, not one. Anyway thought I would post this up.
It seems to be based on current "line-bore" technology for pushing small-bore pipe and conduit under obstacles, but done "on steroids"!
Steve,
You are correct. It's basic structure comes from directional drills. If we added the gear box we could drill with it as well. I will get a few pictures of the actual machine soon.
Edit; here is a pic of most components on the machine. At this point there was alot of hydraulics, wiring and assembly left.
- image.jpg (108.24 KiB) Viewed 1852 times
- image.jpg (108.94 KiB) Viewed 1856 times
Superiorwelding wrote:Steve,
Are some of the weldements in these pics, resemble those cracked welds in your first posts??
John,
You are correct. The thread "cracked welds" did indeed come from the end clamps seen in those pictures. There are still imperfect welds but thankfully they are noncritical in nature. Also in the design we kinda went overboard on strength requirements. Some will in fact need repaired as we are beginning the process of certifying this machine and what a monumental task that is!
Here is one of the cracks from that thread that I actually repaired.
- image.jpg (117.89 KiB) Viewed 1825 times
Here is another project we did about 2 years ago. It is a Recycler used in drilling, slurry walls, vertical shafts and other fields. It is made to ISO container specs so they can be shipped like a regular shipping container. The bottom holds the pumps, motors and fluid, while the top has the shakers and hydrocyclones. It is the only one like it in the world to date. We designed it for a very quick set up and tear down as opposed to others that take a very large foot print at a job site. It is literally plug and play. This machine was shipped to Sourh America for use at our parent company.
- image.jpg (129.08 KiB) Viewed 1825 times
- image.jpg (88.28 KiB) Viewed 1825 times
- image.jpg (105.34 KiB) Viewed 1825 times
