wquiles
    Wed Sep 25, 2013 6:00 am
The thin and short cord on my HTP MIG200 welder was proving inconvenient, so I got a longer, heavier gauge wire 3-conductor (10ga) cord to replace it with. Here are the innards of my welder:
and where the 220vAC power comes inside:
Noticeably thicker wire and conductors:
After wiring the new cord:
and of course, doing an electrical and gnd test! (sorry for being out of focus):
I hope to practice a few more beads tomorrow ;)
Will
    Thu Sep 12, 2013 7:47 am
Tomorrow, make a welding trolley.
Next week make a welding table.
Do the do. Good man.
PS I love the way you copyright your photos.
wquiles
I practiced some more today, and bought steel for the welding table, so getting closer ;)
blaz
    Thu Jan 31, 2013 11:08 pm
Looks good. Just a heads up, our welder manual at work specifically said not to tin (solder) the wires. Check your manual to be sure you are safe.
wquiles
blaz wrote:Looks good. Just a heads up, our welder manual at work specifically said not to tin (solder) the wires. Check your manual to be sure you are safe.
For screw terminals, this is probably why, thermal expansion:
http://reprap.org/wiki/Wire_termination ... _terminals
So in theory the screw terminals could get loose with time. I will keep an eye on these just in case - thanks ;)
Will
