Kiwiwelder1
    Fri Jun 04, 2021 2:06 am
My earth lead is getting really hot when welding MIG spray arc at 27volts and around 210amps. Do I need to increase the size of my earth?
What size wire are you running for the lead and what amperage is the clamp rated for? Even if you are within the range, the earth will still get rather hot welding at those voltages.
Spartan
    Fri Mar 06, 2020 8:59 pm
Well, while you're dealing with that...my truck won't start. Should I change the battery?
Details, man....
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
Kiwiwelder1 wrote:My earth lead is getting really hot when welding MIG spray arc at 27volts and around 210amps. Do I need to increase the size of my earth?
could be undersized lead but also just poor connections. even to the table/part itself.
with mig you must have a good earth lead.
Ilocher
    Mon Jun 14, 2021 6:06 pm
How hot? If it's hot enough to cause a fire then yeah I would definitely upsize your ground. if it's only like 150 deg F I wouldn't worry too much about it.
