Ccbowman
    Tue Mar 16, 2021 7:28 pm
I purchased Lincoln M71 outershield .035 to run in my Lincoln 180 for a home project. I've been able to get a decent bead but it doesn't seem to penetrate that deep like I have read it does. Is my machine too under powered for this wire.
You should refer to this for proper setup for that wire:
https://www.lincolnelectric.com/assets/ ... /c3101.pdf
CTWD is pretty important with these types of wires.
    Thu Dec 26, 2013 12:41 am
    Laredo, Tx
possibly. What WFS were you running?
    Wed Jan 22, 2014 12:00 am
    Connecticut
I have a feeling that machine just doesn't have the necessary voltage to actually run 71M properly. I tried to look up your owners manual to look for a volt amp curve, and one isn't provided in that manual I found on line. But it does say that at 130 amps, you are only producing 20 volts (which is really marginal) and it has a 30% duty cycle at 130 amps. I used to run this stuff (before switching to the 045 wire) at about 24 volts and 300 IPM (150-ish amps)
Multimatic 255
