Anyone have any advice of opinions on what makes a good wire feeder for a portable welder? Thinking of welding up a skid for my Bobcat 250 and adding a wire feeder.
Oscar, does HTP have any? [emoji6]
Use code “Oscar” at checkout for 25% off [emoji16]Oscar wrote:HTP sure does have a feeder. In fact, they have the best feeder you can possibly get to run off a welder/generator:
No it’s not loading for me. I hope you weren’t pulling my leg cuz I spent half an hour googling it lolOscar wrote:If only! lol....did the pic even load correctly? It's a huge pic but I'm wondering if the forum re-sizes for other people when it loads for them....
This isn’t a suitcase wire feeder. This is a stand alone wire welder.Oscar wrote:HTP sure does have a feeder. In fact, they have the best feeder you can possibly get to run off a welder/generator:
Probably why I’ve never seen or heard or one.
A suite case wire feeder is powered across the arc and this HTP unit is not that.
JayWal
Just so you know. After doing some research, HTP doesn’t make a legit suitcase wire feeder for use with your bobcat 250.
Look at one of the units I listed in my first post if you want a proper suitcase feeder for your engine drive.
Will do, thanks.snoeproe wrote:JayWal
I’m guessing I’m stuck with a voltage sensing unit? Since my bobcat doesn’t have a plug that remote control units apparently need.
I don’t need a big 12” roll tho. 10lb roll would be plenty for what I’d do with it.
