I have a Everlast power Mig275S (275amp), running C25 gas. I have knurled rollers for .035 and .045.
I would like to get a roll of Dual Shield for some upcoming projects. I need to weld a lifting eye on a small backhoe bucket. I need to weld some hooks on a tractor bucket. And I need to do some general fab with some 1/4" box tubing for a equipment stand.
All of these jobs seem way better suited for DS vs. short circuit mig. I know stick welding with 7018 is also a viable option but I have no experience in stick welding.
What is a good product for my application? Between Lincoln and Esab there must be 20 different wire options. I'm not real clear what is best suited for a good general use.
With a realistic maximum material thickness of .375" (3/8"), most being .250" (1/4") what would be a better choice. 035 or .045?
I was debating going to a spray process, however the cost of 90/10 125 cu ft bottle is pushing 3-4 times the cost of a moderate roll of DS.
Again with no experience other then conventional mig, tig, my thought is DS would be a easy process to be successful with for my needs
I appreciate your suggestions as this is all new to me.
Just a standard Dual-shield 71t-1 wire will work for your application in my opinion. (note, that's not 71t-11)
Either .035" or .045" should work with the power you have available.
Check out this chart from Washington Alloy for their wire: http://weldingwire.com/Images/Interior/ ... /71t-1.pdf
Based on the power requirements, I chose .035" for my 210 amp machine.
