Hello all,
I have been mig welding approximately once a week/once in two weeks for almost a year now.
I have been welding almost each day for a week or two. Tonight I welded this scrap metal tee joint.
Can you give me some advice on what I could do better? Does correct machine adjustment make for les spatter?
Here are some pictures:
Junior Welder
- Junior Welder
- CB62C883-A896-4179-BD65-D34B45642C2F.jpeg (50.99 KiB) Viewed 1210 times
I'm a 9th grade student teaching myself how to weld.
ESAB Migmaster 250 (MIG)
Miller Two Fifty Twin (Stick)
Junior Welder
- Junior Welder
More pictures
- 24FA2AE2-4DD1-4932-9137-28F192F88325.jpeg (55.5 KiB) Viewed 1209 times
Junior Welder
- Junior Welder
More pictures
- 6839EAE1-1F5D-49BE-9B91-2F33249EE0CF.jpeg (31.47 KiB) Viewed 1209 times
Junior Welder
- Junior Welder
More pictures
- 0F811258-2EFB-49B5-8048-BD761B768F5E.jpeg (28.21 KiB) Viewed 1204 times
- tungstendipper
Are you using Flux-core wire?
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
If he is, he needs to reverse the cables and run DCEN to help eliminate the spatter.tungstendipper wrote:Are you using Flux-core wire?
Beads look good, travel speed is good, consistent tie-ins, heat looks right. Spatter is killing you.
theaceofgates
- theaceofgates
try adjusting wire speed just a bit. It might help.
Junior Welder
- Junior Welder
No.tungstendipper wrote:Are you using Flux-core wire?
I’m running 0.035 ER70S-6 solid wire with c25 gas
Junior Welder
- Junior Welder
Up or down?theaceofgates wrote:try adjusting wire speed just a bit. It might help.
Junior Welder
- Junior Welder
What do you mean by CWD?
Junior Welder
- Junior Welder
Ok thanks. As far as I know, I can’t adjust the contact tip recess on my gun. But I do try to hold a tight arcLtBadd wrote:Contact to Work Distance, HERE is a short write by Lincoln ElectricJunior Welder wrote:What do you mean by CWD?
Junior Welder
- Junior Welder
I pushed this one. The Migmaster 250 doesn’t have any digital displays which tell the volts or ipm but I can tell you what I used If that helps. C25 gasWarrenh wrote:Are you pushing or pulling and what settings are you using. Also, what gas? I am going to guess pulling from the look of the weld.
Sometimes you can tap the internal threads on the cup in or out. I’ve also ground down the copper tip to make the adjustment.Junior Welder wrote:Ok thanks. As far as I know, I can’t adjust the contact tip recess on my gun. But I do try to hold a tight arcLtBadd wrote:Contact to Work Distance, HERE is a short write by Lincoln ElectricJunior Welder wrote:What do you mean by CWD?
