Got a hold of a roll, thought it would be interesting to try it out. Don't know on what though
- DLewis0289
Hastelloy=$$$$$$$$$$$$$
Just out of curiosity how did you get a hold of a roll of Hastelloy-C? Usually only used in chem plants with corrosive processes stainless steel won't handle.
Just noticed it is X not C, has hi temp properties as well as superior corrosion resistance.
Easy: EbayDLewis0289 wrote:Hastelloy=$$$$$$$$$$$$$
So, for filler wire of this caliber, naturally I had to wait until a very sensitive weld procedure called for it. Something with insanely strict and specific procedures to properly utilize it's extreme corrosion and heat resistance.
Turns out I hated having to reach for a socket when I want to switch polarities from MIG w/ 70S-6 to Flux-core on my Millermatic 211. It has two small flanged nuts that are recessed into small plastic "pockets", so you have to reach for a socket.
So I TIG'd some wingnuts onto the back of the stock nuts. With Hastelloy-X.
Incredibly precise jigs/fixturing to hold tight tolerances.
Puddle flows nice and smooth, reminds me of 304L. Now I can switch polarities quicker. I don't have a rotary positioner to chuck these up in, so bear with me.
Here they are installed and tightened.
The End.
The End.
Well..wheres the WPS
Sweet find, that's an expensive roll of wire
