I came across this awhile back while looking something up and thought it was good enough to bookmark...should help you.quadrod wrote:Is there a quick guide to the welding characteristics of different steels? Or what steels are readily weldable?
http://www.twi-global.com/technical-kno ... teels-019/
- DLewis0289
Probably one of the best books you can have in your library is the Machinery's Handbook. Has survived for over 100 years and just gets better every addition. It should have everything you need for this.
And about any alloy can be welded (stainless steel to aluminum if you like)
Jody recommends the book, "Metals and How to Weld Them".
DLewis0289 wrote:Probably one of the best books you can have in your library is the Machinery's Handbook. Has survived for over 100 years and just gets better every addition. It should have everything you need for this.
Worth everypenny
