aluminum questions: ending a weld and sq. tubing
Posted: Tue May 03, 2016 11:33 pm
So I've been practicing on my aluminum technique and have a few questions.
I'm using a AHP 200x set at approx. 130A max, stock foot pedal, 170 Hz AC, 35% cleaning, 3/32" 2% Lanth. tungsten, 1/16" 4046 rod.
Freshly cleaned 1/8" thick Aluminum plate
1) ending
When I am running a bead i try to taper off at the end but always seem to end with a dimple in my puddle. I know that's not a good thing. it seems as I am tapering off the arc just stops abruptly, not the slow shrinking arc that I see on videos. If I taper too slowly I end up overheating the spot and end up with a large dimpled spot. If I taper too quickly I end up with a smaller dimpled spot. I just can't seem to get a non-dimpled spot at the end. Should I be lifting the torch as I taper on the pedal and circle the torch?
2) sq. tubing technique
I am also practicing on 1.25" sq tubing. very sharp corners unlike the rounded corners of steel sq. tubing. I cut a section of tubing and then weld the two pieces back together.(no pics at this time) I find if I start my bead on the corner I get a very rounded corner and sometimes a dip. Am I expecting too much trying to maintain the square edges? Or should I start my bead on the middle of the wall and travel towards the corner? Stop at the corner? Or should I try to continue around the corner and end in the middle of the next flat? lots of questions just trying to figure out a technique for dealing with square tubing.
thanks.
steve
1) ending
thanks.
steve
