uguralp.tpx
    Thu Mar 17, 2016 8:06 am
Hello all!
I need a small advice about making an extra cable with a starting switch for the TIG welding torch. What I want to do is fixing the welding torch and being able to start the process without touching the torch button. To do that, i need to build a new cable with a start switch (basically the same button on the torch) to connect the torch cable on the on side and the welding machine on the other side. In other words I want to bypass the welding torch button and build my own and press it from a distance. The welding machine is Castolin CastoTIG 1611DC and the cable connection is with 5 pins. I am attaching the torch connector's picture. Also url of the machine for the front panel. I hope someone could help me out, I am really not familiar with the electronics and cables..
Thanks!!
Alp
URL: https://www.castolin.com/product/castotig-1611-dc
Sandow
    Fri Mar 04, 2016 4:52 pm
    Central VA
Without measuring the plug I couldn't tell you if these will fit but this style of connector is called an aviation plug.
http://www.amazon.com/uxcell-Thread-Avi ... +connector
Your pin outs for on/off are bridging 1 and 2 with a momentary on switch. You can test this by briefly putting a U shaped copper wire in those pin holes.
-Sandow
-Charles Dickens
