Hi All,
I was thinking about proper gas shielding and in particular gas lenses and a couple of questions came to mind.
Why do gas lenses fail to shield properly? Is it because of contamination buildup on the mesh or something else like heat distortion?
Can they be cleaned in an ultrasonic cleaner and refurbished or are they simply expendable?
Sorry if these are silly questions.
Cheers.
Flo
dirtmidget33
- dirtmidget33
If you have a lot of spatter on the screen it is impossible to get it out, but you can remove a couple of screens before you notice any major change in shielding. Personally I would remove the first screen and use it. If it gets full of spatter toss it and replace. I charge for gas lens replacement on every job I do. Even though I don't replace them that often. The only time I get spatter really is on case repairs. Otherwise the lens just develops a discoloration from being heat cycled. You might be able to shine them back up in cleaner but I have noticed no difference from a heat cycled one to a new one.
kiwi2wheels
- kiwi2wheels
If you are having this problem with new lens, there have been ( and probably still are ) some no name brands than will give this problem.OzFlo wrote:Hi All,
I was ..........................................
Cheers.
Flo
Stick to known brands , e.g.,CK Worldwide, Miller/Weldcraft, Abicor Binzel, etc. There were instances sometime back when junk gas lens were being marked and sold as Weldcraft.
- MosquitoMoto
As a relative noob I've had some blow-ups the size of IED's and I've shut down the torch thinking "Well, that will have screwed my lens" but to my surprise none of my lenses have ever copped platter.
I had one become quite 'smoky' looking, washed it in acetone and it came up like new.
If I ever had one spattered I think I'd just use the 'if in doubt, throw it out' rule.
Kym
Kym
Thanks for the replies. I have had a couple of gas lenses from different (and I would assume reputable) suppliers that have performed quite well. The one I am using at present was sourced from BOC Gases. I guess they probably get them from China.
The one I'm using currently seems to be biasing the shielding and not providing even coverage, although to the naked eye there doesn't appear to be an obvious reason as to why this is the case. I might try the acetone soak trick and if it doesn't fix it then I'll swap it out.
Flo
Flo
I buy stainless mesh on eBay just in case I dip the tungsten and get spatter BBs on an otherwise perfectly good gas lens collet body. I have 4130 chromoly tubes wthat I sharpened the edges in just the right sizes that I can punch out circular mesh screens on a 1/4" chunk of copper real quick
And that set up works well? Could you not use a wad punch?Oscar wrote:I buy stainless mesh on eBay just in case I dip the tungsten and get spatter BBs on an otherwise perfectly good gas lens collet body. I have 4130 chromoly tubes wthat I sharpened the edges in just the right sizes that I can punch out circular mesh screens on a 1/4" chunk of copper real quick
Well the mesh screens are pretty much identical, so I don't see why it would work. what's a wad punch? Nevermind, just Google'd it. Seems like a pretty expensive alternative when I already have tons of chromoly tubing laying around.OzFlo wrote:And that set up works well? Could you not use a wad punch?Oscar wrote:I buy stainless mesh on eBay just in case I dip the tungsten and get spatter BBs on an otherwise perfectly good gas lens collet body. I have 4130 chromoly tubes wthat I sharpened the edges in just the right sizes that I can punch out circular mesh screens on a 1/4" chunk of copper real quick
- GreinTime
If anybody could, he could And my brother. My brother could probably argue that lolOzFlo wrote:Mate if it works then who can argue with that!?
kiwi2wheels
- kiwi2wheels
One answer. But no memtion of the screens being available as a part #.
http://www.tectorch.com/Speedway%20Tig% ... s_lens.pdf
I think the idea is that you pull the outer screen off once and then if the second screen becomes contaminated then you scrap the lens. I don't think they envisage replacing the screens..kiwi2wheels wrote:One answer. But no memtion of the screens being available as a part #.
If you pull a screen out of a gas lense then it is no longer working as it was designed to. It may work ok but it's not the same. The screens create back pressure and causes the gas to leave the cup in a more even pattern. For better coverage. It also has to do with making the gas flow stream laminar as it leaves the cup.
kiwi2wheels
- kiwi2wheels
But if you take out the top (2nd ) screen and replace it with a new one, you're back to original.OzFlo wrote:I think the idea is that you pull the outer screen off once and then if the second screen becomes contaminated then you scrap the lens. I don't think they envisage replacing the screens..kiwi2wheels wrote:One answer. But no memtion of the screens being available as a part #.
Maybe machine up a pusher to replicate the original assembly process ?
- Copper plated gas lens
- image.jpeg (44.63 KiB) Viewed 1806 times
Mix distilled vinegar and peroxide 1:1 and toss in some stripped braided core wire. Pop the mix in the microwave for a minute and it should start fizzing. Repeat heating cycles until it no longer fizzes when heated and then plate with your target metal on the negative lead and some extra copper wire stripped out as the positive lead. Takes about a minute with a 12v power supply.
-Sandow
-Charles Dickens
-Charles Dickens
Interesting, can the microwave be used for food after that?Sandow wrote:Mix distilled vinegar and peroxide 1:1 and toss in some stripped braided core wire. Pop the mix in the microwave for a minute and it should start fizzing. Repeat heating cycles until it no longer fizzes when heated and then plate with your target metal on the negative lead and some extra copper wire stripped out as the positive lead. Takes about a minute with a 12v power supply.
-Sandow
Well, the vinegar and peroxide vapors may result in a clean spot amongst the chili splatters but if you can live with the "patina" being damaged it should be fine. The end product is copper acetate which is terrible for you if you are a fish but is mostly harmless if you are human...
-Sandow
-Sandow
-Charles Dickens
-Charles Dickens
Considering my low skill level at TIG so far, I think I'm going to try this with one of my lenses, and hopefully save some aggravation and money.
It's also just fun to play with electroplating...
-Josh
Greasy fingered tinkerer.
If you guys like that and are using the CK pyrex sleeve, you might like this too:
http://www.amazon.com/Fused-Quartz-Tubi ... rtz+Tubing
I've used this for about a year after having broken and melted a few of the Pyrex sleeves for $10 each... It needs to be cut with a diamond wheel so have no illusions of scoring and snapping it. The stuff is really tough though and repeatedly dropping it and covering it in splatter ended up with it looking like this after a few months with an occasional brush out. At this rate a meter of it is looking like a lifetime supply lol
-Sandow
- Fused quartz cup
- image.jpeg (36.89 KiB) Viewed 1759 times
-Charles Dickens
-Charles Dickens
Sooo-you want to whack off a hunk say a foot for $10?
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
Sure why not. You can PM me with details.rick9345 wrote:Sooo-you want to whack off a hunk say a foot for $10?
Make sure you wear a respirator when you cut or grind it though. Silica needles are not great for you.
Cut it with a thin high speed diamond wheel like a dremel. Angle grinder blades will just chip it. If you have an oxy torch, you can flame polish the ends. If not you can chamfer the insides and outside edges with diamond grinding tools. Ceramic abrasive belts work too and make squaring the ends off after grinding easy.
-Sandow
-Charles Dickens
-Charles Dickens
