baer19d
    Tue Sep 08, 2015 6:21 pm
I'm a novice TIG welder and I'm trying to figure out what is going on. I helped someone by TIG welding something on their winch bumper and even after sanding with a flap disc and wiping everything down with acetone there were still contaminates in the metal that would burn out when I started welding. Did I not prep something right or is it just oils and other crap impregnated in the pours of the metal? What can I do to prevent this in the future?
Thanks
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
Pictures please.
Could be the machine or the metal.
AFR_Autoworks
    Mon Nov 30, 2015 2:35 am
    Red Deer, Alberta, Canada
I am in for pictures as well. There are allot of things that could be happening.
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
machine, setting, filler??
    Thu Aug 13, 2015 11:38 pm
    Scranton/WilkesBarre, Pennsylvania
was it galvanized ? I recently had a prob like that. Flap disc'd off all the galvy ...still was messy
One thing I encounter a lot is a surface prepped by media-blast, and primed with a zinc-bearing primer. I find these exceedingly difficult to prep for welding. (Even a non-zinc primer on a media-blasted surface will make soot when you weld it, but zinc is a bear!) I have to define precisely where my weld is going to go, and grind it deeper than normal prep would suggest. To no weaken the area outside the weld zone, I have to leave the contaminates in place, and deal with the crap boiling off the sides. This makes it difficult to see clearly what I'm doing, and particularly suck in a lap-weld as crap will still boil out of the HAZ under the lap.
I'm not saying this is what you encountered, but it is one possibility.
baer19d
Unfortunately I can't get any pictures. I was thinking though, It seemed like at first it welded fine but after a while it would start boiling. I didn't clean the back side of the welded area before I welded so could it be that once the area heated up it started to penetrate all the way and that's where the contaminates came from? On some of the areas I ran several beads and the first one was beautiful and the second and/or third didn't. I don't remember the settings exactly, but it was around 125 amps and 1/8 mild steel. I used 3/32 ER70S-2 filler rod.
Yes that is a likely event.
