- jumpinjackflash
OK The Ti tubing was a bust. Got the materials in for the job from customer...... SS on the economical side and have this piece here. 2 into 1 merge collector that someone put together. Nice welds on tube flanges but what happened on the merging tubes? Wire feeder? Do I need to just cut and Tig it to make sure it doesn't crack apart?
- 1226151000.jpg (25.48 KiB) Viewed 356 times
J.J. Flash
J.J. Flash
Looks like they bought a merge already fabbed, it was mig welded pretty hot, I'd say in spray transfer. Should hold just fine...it would be quite a job to cut out and reweld TIG, not knowing what your going to run into once you start removing the weld.
It is stainless right?
