How to repair a Tig welding hot crack.
Posted: Sat Dec 05, 2015 3:13 am
by Tom Seat
I am Tig welding a 2 mm. stainless steel plate for the replacement of the Bainmarie Food Heater.
My welding was good at the first but it begun cracking and I can no longer repair the cracks as it begun to multifly.
I used 50 amps on the welding mach in reverse polarity.
Please share me your knowledge about how to repair my work.
Thanks a lot.
Tom Seat
Re: How to repair a Tig welding hot crack.
Posted: Sat Dec 05, 2015 10:35 am
by exnailpounder
Welcome aboard! Post up some pics if possible. Also describe your settings ( amps, tungsten type, gas flow rate, gas lens, no gas lens, cup size) the more info you can relate, the faster you will get answers. We have some stainless experts that will be along to help you.
Posted: Sat Dec 05, 2015 12:08 pm
by mcostello
Should that be straight polarity?
Posted: Sat Dec 05, 2015 1:11 pm
by Braehill
Tom,
Welcome to the forum.
The question I would have first is what grade of stainless are we working with here, and in what configuration.
Usually when you're getting hot cracking, more welding just makes it worse. You need to give us more specifics before you keep trying to "weld it out". That's thin material and easy to overheat.
Any problem solved through cyberspace needs to be presented with as much detail as possible, otherwise you'll answer 50 questions to get just one solution.
Posted: Sun Dec 06, 2015 4:39 pm
by Tom Seat
Thanks for your reply, Jody.
The settings that I used are the ff:
Amps - 45
Tungsten type - MIGA SUPER BLUE (Migatronic) -1.6 x 175mm
Current range - Amp DC -70 - 150
Amp AC - 50 - 100
Gas flow rate - 2,5 bar l/min
Cup size - 7
No gas lens
Filler used - ? ?? stainless steel
Welding Mach - KEMPPI Minarc
I used stainless steel filler but there's no type indication in the box.
Is the filler should be the same type with the base metal? Probably that 's one cause of hot cracking if the two are of different kinds.
Thanks Jody. I appreciate your concern.
Posted: Sun Dec 06, 2015 4:58 pm
by Coldman
You have given us a gas pressure and flow rate. Can't be both. Which is it? If it's flow rate you need to be up around 8 l/min at least.
Posted: Sun Dec 06, 2015 5:31 pm
Most tig wire will have a sticker or a set of numbers stamped on each rod. Sometimes it's hard to read.
Posted: Sun Dec 06, 2015 5:32 pm
And lack of using enough filler can cause stress cracks in some metal.
Posted: Mon Dec 07, 2015 6:40 am
by Tom Seat
Coldman wrote:You have given us a gas pressure and flow rate. Can't be both. Which is it? If it's flow rate you need to be up around 8 l/min at least.
Cheers Coldman. Tried to raise up the flow rate as well. Ssame thing happen.
Posted: Mon Dec 07, 2015 8:40 am
by Coldman
Are you purging the back side of the weld or welding up against a dissimilar bar? Can you give us a pic of the joint and prep so we can see what's going on? Right now we are only guessing.
Posted: Mon Dec 07, 2015 8:23 pm
Is this cracking on the "food" side, or the "pretty" side?
It matters. 316 filler is dandy for the "food" side.
The "pretty" side could be damn near any alloy China can sell under the nickname "stainless".
