jmn
  • jmn
  • New Member
    Mon Dec 29, 2014 1:19 am
Does anyone have experience tig welding 01 to 01 or A2 to A2 tool steel, unhardened?
I would like to make some specialized socket handle style woodworking chisels and would like to weld the socket handle portion to the 1/4" thick flat stock rather than machining the whole tool from a large piece of bar stock.
What is a good filler rod and a good pre-heat temp and cool-down procedure?
Thanks
    Thu May 07, 2015 11:46 am
    KY.
I've tried welding 0-1 and it didn't work. It breaks easily. I haven't tried welding it and then annealing after welding, but that might work. Welding is going to make it very hard in the HAZ and it will break. I checked on the correct filler wire for welding 0-1 and it was very expensive.
I have welded quite a bit if A2, but it was only build up in wear areas. I use a air hardening rod, but this is not welding 2 pieces together, just build up on a worn part.
I'll be watching this to see what answers you get.
Freddie
Cricket
    Tue Aug 20, 2013 10:49 pm
    Oregon, WI
I've done A2. 3/32 A2 wire for the filler and very high temp preheat (450°C +). Right after the welding the piece goes into annealing oven for full annealing cycle.
O1 will be more difficult because it has higher quench distortion than A2.
I would call and talk to a tech at Weld Mold, they've been helpful for me in the past and seem very knowledgeable.
http://www.weldmold.com/
